For Sale Big Clearout - S14 Cut Knuckles, S15 Brakes, SR20 Crank, 1JZ Parts, SR20 Parts + More
Thread in 'Parts for sale' started by chopaholic, May 24, 2020.
  1. chopaholic
    chopaholic Well-Known Member
    Ireland/Lincoln
    Having a massive garage clear out when my car is away having some work completed, all prices are OVNO, postage can be arranged at buyers cost, paypal fee's are not included. All items located in Lincolnshire.
    If you have any questions or require more pictures or information please let me know via private message.
    Ta6jpHD.
    S14 Cut Knuckles for extra lock, bought ages ago from here but never used, have gone for Geomasters now so not needed - SOLD
    S15 Brakes, front calipers, rear calipers, handbrake lines, discs and rear dust plates. All came from my S15 in working condition -SOLD
    SR20 crank shaft, this came on an SR20 I bought some time ago, looks like the previous owner tried to remove the flywheel with a jackhammer, will need a few mm skimmed off the rear face before fitting again. Everything else looks to be in good condition - £60
    20GsLQD.
    PreF1Ik.
    1JZ VVTI OEM Injectors, all from my fresh engine - £40
    1vnqFIH.
    SR20 fan shroud with electric fan, needs a clean but seems to be complete and no cracks - SOLD
    SR20 power steering pump x2, one from a redtop one from a blacktop, unsure if there is a difference in them - £30 each (REDTOP ONE NOW SOLD, BLACKTOP ONE AVAILABLE)
    cGbDVlP.
    HPI Air filter - £25
    CDAjoUL.
    SR20 Rocker Stoppers - £10
    ctmT97D.
    Walbro 255lph, came out of my car before upgrade to 450lph - SOLD
    1JZ VVTI Viscous fan, 2 blades have a few chips out - £25
    4yQ5beJ.
    1JZ VVTI J pipe and OEM manifold - £25
    RArTDqX.
    1JZ VVTI JZS171 engine mounts, probably fit others - £30
    5MtbJgP.
    Bs7K5HC.
    mjGsEm2.
    VdsFSua.
    LtOcydp.
    VNCskVU.
    #1 chopaholic, May 24, 2020
  2. chopaholic
    Ireland/Lincoln
    20 front prop manual SOLD
    1JZ VVTI Auto flex plate - £20
    pY2VDLa.
    S15 Centre console buttons - £20
    MKkV2VG.
    S15 Spec S brake master cylinder - £20
    x9bxBxD.
    Nissan Micra brake master and servo, allows lots of space for engine swapped SBodies which are running stock brakes - £25
    Xim8RET.
    S15 OEM space saver spare - £20
    bkVZUPb.
    E36 Aluminium door cards, ive never used or fitted these, were left here from an old race car - £20
    RtPLsgl.
    S15 Spec S automatic radiator - £20
    cryFWeX.
    S15 Spec S MAF - £20
    tJf2Bhf.
    S14/S15 adjustable front tension rods SOLD
    SR20 OEM gearbox shifter base - £10
    bLhwEHp.
    SR20 aftermarket shifter - £10
    ap4blLD.
    1JZ VVTI Lambda sensor - £10
    fYKnk5I.
    1JZ VVTI oil cooler oem - £20
    so6fQp1.
    WfneG72.
    m8imI7D.
    #2 chopaholic, May 24, 2020
