- I had the turbo fitted to a standard CA but it was too laggy for my set up so went back to T2871R. This would be better suited to a 2 litre or above. Turbo was fitted and only run on the dyno once, so basically as new just wants a wipe clean if you're bothered. The turbo is a T04E T3/T4 hybrid with a T4 inlet and V band turbo out. I think it is a 1.06 AR rear housing. Comes with oil feed line, V band and various gaskets. Bought from XS Power. Turbo with fitting bits and bobs £250 - Top mount manifold for CA18DET with T3 and T4 turbo flange and 38mm 2 bolt wastegate flange. Temperature probe hole has been welded up. Manifold £100 -Also got a brand new unused CA18 HKS turbo timer and wiring harness for sale, can post to mainland UK for £40 HKS Turbo timer & harness £40 Collection only (located in south Cumbria/Lake district), although I can bring to any of the BDC rounds 2014. Will be at Knockhill this weekend if anyone wants parts.
