Black s14a, Breaking or for sale?
Thread in 'Drift cars for sale' started by danfst, Jun 9, 2015.
  1. danfst
    danfst Member
    Ipswich
    I don't have the time or equipment to fix this, and do not have time to completely break it. A weekend or two spent on this in the correct hands. And you will have a lovely s14a for a dirt cheap price.
    The car was used daily, until I knocked a hole in the wheel arch. Has had no test from 1 august.
    £3200. Can be cheaper by removing parts. EG bring your own wheels and brakes and It'll drop to £2500.
    Bad points:
    -****off big hole in the wheel arch, will require engine out and them tubbed or remade.
    -5cm size hole in the one of the sills,
    -Rear calipers leaking
    -strut tops starting to rust
    -Engine is currently half out and has no fluids. (if someone came to pick it up as a whole bring some fluids and we can get it going in 30 minutes, the car ran well and strong.
    -Manifold stud snapped, easy to take out when the engine is out.
    -VVT rattle
    Spec list and parts:
    Full Apex exhaust with decat
    Greddy Frontmount with hardpipes, which needs new mounting points.
    Huge Cone filter.
    Walbro 255 fuel pump.
    Greddy profec b spec 2 boost controller.
    Greddy turbo timer.
    HDev Manifold.
    Hdev Stage 1 map.
    Tomei Expreme elbow
    356mm 8 pots on the front with braided lines.
    Vertical hydraulic handbrake.
    Apex Half Cage.
    ACT Heavy duty Clutch
    Kazz 2 way diff
    Apex coilovers
    Vented Fibreglass bonnet with catches.
    Vented 25mm wider front fenders.
    Pillar boost gauge
    Cheap eBay steering wheel
    Neochrome nuts (not shitty chinese ones)
    Longer studs on the front
    XXR 527's
    Rusty Strut Tops:
    Passenger Side Sill:
    Subframe mounting points, a rust treatment, wool and under seal will be enough here.
    Middle to rear of the sill, not bad at all.
    Front of the sill, has a hole. and damage from incorrect jacking. Will need to be patched.
    Drivers side sill:
    Subframe mounting point, same as other side. not bad at all.
    rear 2/3 of sill, Not too bad at all. Need some treating and underseal.
    Chassis rail:
    Wheel arch hole:
    #1 danfst, Jun 9, 2015
  2. Drift Dango
    Drift Dango Active Member
    Bolton
    How much complete
  3. Bigdave2000
    Bigdave2000 Member
    Gloucester
  4. Kingk
    Kingk Member
    Essex
    Is the cage bolt in? If it is. How much? Also how much for wider wings?
  5. danny_boi
    danny_boi novice
    southampton
    Engine bay fuse box and all wires to a from please
  6. danfst
    danfst Member
    Ipswich
    £3200 as is.
    £2200 with brakes and wheels removed.
  7. Kingk
    Kingk Member
    Essex
    Not breaking down any more now?
  8. danfst
    danfst Member
    Ipswich
    I'd ideally like to do as little breaking as possible.
  9. J4CK
    J4CK Member
    Ghetto
    You have a PM
  10. danfst
    danfst Member
    Ipswich
    Edited:
    #10 danfst, Jun 12, 2015
  11. danfst
    danfst Member
    Ipswich
    How is it looking for price?
  12. danfst
    danfst Member
    Ipswich
    £2800, or £1900 if you bring your own wheels and I remove the brakes.
  13. danfst
    danfst Member
    Ipswich
