BMW E34 diff diff options?
Thread in 'Technical' started by Polo, Oct 21, 2008.
  1. Polo
    Polo Sr20 parts man!
    S-body Automotive.com
    As above what cheap options have i got for a tighter diff? dont want a welder as its my daily, just an LSD will do.
    What diff out of what cars fit?
  2. DaveM
    DaveM flickwandoops
    Stroud / Fife
    What E34 have you got? Jeek and Chizfab will testify that the LSD in the 535 is sweeeeeet.
  3. Bon Bon
    Bon Bon It'll be fine
    Solihull
    Chunk is selling a 535i sport diff..... depends on what e34 it's going in though
  4. Polo
    525 se estate:D Surly you can swap and change cassings?
    Chunks the man then, pm your way dude:thumbs:
  5. 20vWill
    20vWill Active Member
    Doon Sooth
    No.
    535 is 210mm, 525 is 188mm.
    Not sure if you can swap it in complete with the shafts though, the 210 might mount differently. Should work if you swap the entire rear subframe over as one though, even then you may need to use your 525 prop flange as the 535 one might be larger PCD.
    #5 20vWill, Oct 21, 2008
  6. Polo
    Ok then:cry:, whats the differance in ratio's, input and output shaft flanges?:D Is the cassing just bigger? il make the fricker fit!!
  7. Bon Bon
    Solihull
    I'm pretty sure driveshafts are the same but prop is different, you'd need the prop off the 535 too, 525 is big donut like 535 so should just swap over.
    If you need the shafts they'll swap too, but hands off, I need them off chunks car. Can source elsehwere if you buy it all off him though.
  8. Bon Bon
    Solihull
    Incidentally I've got a MEGA MEGA rare 3.91 LSD in tooootally mint condition, low miles if you want it. I've kept it for ages since I was gonna put it in my V8 project but that died a death.
  9. Polo
    Will that fit in or is it the same as the 535 fitment?
    And i did say cheap?
  10. Bon Bon
    Solihull
    It's worth a fair bit, more than the taller ratios, but I dunno £175 to you sir if that's cheap enough to spark interest. I think I've got a back half of a prop I could throw in too, 99% sure, and yeah it's actually out of a 735i auto with LSD but 100% identical fitment to 535i.
  11. Polo
    think its sorted, gota go and rape chunks car for prop, shafts and diff:D You can find the shaft else where bon:thumbs::p
    So as far as the fitment into the frame goes, thats ditterant too? same sort of differance to a e36 1.8 diff to a 2.8 diff? mounting lugs and holes in differant places due to the differance in size? Just a case of welding in new brakes for it?:confused:
  12. Bon Bon
    Solihull
    Frame's the same! :)
  13. Jeek™
    Jeek™ Active Member
    lochgelly,Fife
    Im after an open 535 diff to get welded up was gonna suggest a swap but now know they are different sizes!
