Bmw e36 316 2.8 Boston green 316 2.8 swapped saloon •8 months mot •Partially stripped, no rear seats/seatbelts and no interior in the boot •Paintwork isn’t the best, body work overall is in good condition Full bare block rebuild,full gasket set, stem seals etc, metal impellor water pump, ally stat housing, new rad, n fan clutch, dts ecu ews removed, mapped but on standard limiter, New clutch, good dual mass, new slave, all fresh oil throughout. New brakes, back plates, shoes and spring kit, handbrake cables, pipes and flexis, abs deleted, calipers fully refurbed in gold with new piston and seal kits. New bearings, ball joints/ arms, using m3 style twin rose joints on the trailing arms, drop links etc. Fully powerflexed, inc diff bushes All work done by previous owner about a year ago. •Fibre Factory overfenders •DW steering wheel •Momo hub •Direnza spacers 25mm front, 30mm rear •Japan racing JR12 9J wheels •HMS roof spoiler •B2D short shifter •WDS Side skirt extensions •WoL extended arms •Rack spacers •Welded diff •HSD coilovers •Ltw wing All parts above are at most 4 months old £3000 or swaps
