Bmw e36 325 drift ready £1200 - Kent
Thread in 'Drift cars for sale' started by REDTOm, Jun 6, 2015.
  1. REDTOm
    REDTOm Member
    Kent
    Bmw 325 coupe for sale.
    M52b25 low mileage engine fitted
    M50 inlet manifold and conversion kit
    328 exhaust, new 328 rad
    Induction kit
    Coilovers
    E46 lower arms
    Rack spacers
    M3 accenttric lollypops
    Polybushes
    M3 full kit
    Abs deleted
    3.15 ratio welded diff
    Solid driveshafts
    Hydro lines run into the car ready to fit a hydro (no hydro itself)
    Ready to skid, drive away, could do with some rear trailing arm bushes as they are knocking and a clean up.
    Starts runs and drives spot on, skids well. Arches been rolled for meaty wheels by previous owner.
    £1200, located in Kent.
  2. jackyg rs
    jackyg rs Member
    Where abouts in Kent are you?
  3. REDTOm
    REDTOm Member
    Kent
    Lenham me17, delivery possible for extra
  4. REDTOm
    REDTOm Member
    Kent
    To the top
  5. REDTOm
    REDTOm Member
    Kent
    If gone this week £1000 cash takes it first come first served
  6. Sukhsukhi
    Sukhsukhi New Member
    Alright mate would you swap for a mk6 Zetec s? I'm from bexley heath so not too far!
  7. ben21
    ben21 New Member
    Ireland
    Does it have a MOT?
  8. FAbity6032
    FAbity6032 Member
    What is a M50 inlet manifold and conversion kit?
  9. LiamE36
    LiamE36 Active Member
    M50 inlet manifolds (originally from the M50B25 engine) have bigger ports than the M52 manifolds. The conversion kit is just a few extra parts that's are required to fit it to this engine.
    #9 LiamE36, Jun 21, 2015
  10. FAbity6032
    FAbity6032 Member
    I guess I just missed the part were it says it is a 323 ? Because an M50b25 is still faster than a 323i with a manifold conversion kit which this is. There are lots more parts involved than just the intake manifold and he is selling it as a 325i.
  11. suttin8274
    suttin8274 Member
    That car is a 325 323 did not come out That eraly and u can see its a m50 engine as oil cap is at the back of the engine so he just selling a 325 like it said
  12. LiamE36
    That's becuase he didn't say it was a 323, says it is a 325 with an M52B25 fitted which is probably just a typing error becuase as "suttin8247" has said you can see the things that show it's an M50.
  13. FAbity6032
    FAbity6032 Member
    I guess it is an m50b25TU with the vanos. But I still don't get the manifold conversion thing? Don't all 325i's have that? This is confusing as fuck.
  14. LiamE36
    No the engine will be M50B25 if it's the standard engine, so yes the M50 manifold is standard on the 325.
    I'm sure Tom will explain all when he's next on here.
  15. REDTOm
    REDTOm Member
    Kent
    It's a 325 car, it's had a m52b25 engine fitted which is from a 323 but has the m50 inlet etc fitted. Not sure what the confusion is really... Not trying to hide anything the engine is the first thing I mentioned in the advert.
    Cheers Liam for answering I hadnt seen this so didn't answer quickly lol
  16. LiamE36
    No worries.
    Deffinatly worth checking if it is actually an M52 lump though.
    It has an M50 rocker cover and an M50 engine wiring loom and as far as I'm aware the M52 won't even run on the M50 loom as some/most of the plugs are different. Worth a double check.
  17. REDTOm
    REDTOm Member
    Kent
    Come on do you think I would have missed that.. Lol It has a metal m50 cover which are better, and loom is an m52.
  18. LiamE36
    Just wondered as the M52 loom has the coilpack feed from down near the brake servo not on top of the manifold as the pictures above are showing?
