BMW E36 328 compact drift spec Reg : W541 JCT, registered as 316 (low road tax & insurance), road legal, MOTed (10 months remaining). V5 in my name. Built by Ross@Driftgarage & thoroughly maintained & serviced by Alistair@Unit18 (lots of invoices as proof of full service history since the car was built). Shell @135k miles, engine @95k. Shell is solid, no rust issues, sills are good, jacking points rock solid. M bumpers and skirts. Motorsport bonnet catches. Fully stripped & very light. New radiator and expansion tank. Viscous removed, additional big electric fan with dashboard switch, bespoke raised bonnet mounts for improved air flow. Digital water temperature indicator - car is running at 65 degrees on road and under 80 degrees whilst drifting ! Very good 2.8 engine, no oil leaks, no fumes, it doesn't eat oil at all. M50 inlet manifold, the ECU has had ews and abs delete, rev limiter raised, hard cut delete, throttle response sharpened up. Sport air filter. New sparkplugs. Purple tag steering rack, wheel spacers, rack spacers, new arms, lollipops, modified hubs - it has more than decent lock. Lowered on Maxpeedingrods coilovers, adjustable height & damping, adjustable camber plates, topmounts, new bushes, new droplinks. Bigger brakes, front drilled discs, brand new rear Brembo discs & pads, also had a new caliper & brake fluid changed & serviced 2 weeks ago (all the rear refresh ~400 GBP). Driftworks original rail seats, bucket seats in very good condition (passenger is Sparco Sprint), brand new 4 point TRS passenger seat belt, 6 points driver seat belt anchored to welded eyebolts (Race Safety Accessories FIA compliant harness bolt stress plate & Race Safety Accessories 1" harness eye bolt M10x1.5 thread). Rear welded strut brace. Full alignment done after every 3rd drift day. Snuggly fitted handbrake, deep dish steering wheel (horn still working). 3.45 welded diff with good shafts. Welded jacking bar, makes wheel changes so easy and fast ! Has had original BMW exhaust mounted on about one year ago, it isn't loud under normal usage scenario but has a nice growl when revved up, also won't cause MOT trouble. 1kg ABC powder fire extinguisher nicely secured in passenger's footwell. I'll keep the driver seat & the 6 point seat belt so you'll get the passenger one and the 4 point new seat belt. Bad bits : Bit of paint bubbles on rear arches but the arches are solid it's just surface rust. Front wings have some corrosion in the lower area - only visible when the car is on the elevator. Paintwork is mediocre, has some discolouring and the bodywork is a bit tatty as it's a drift car - usual battle scars. Windscreen has some small stone chips. Reversing white lights aren't working. Offside tail light is cracked but no water ingress so far. 1.600 GBP including 12 wheels : 4x 16" silver alloys with good tyres, 4x 15" silver alloys with brand new tyres, 4x yellow 15" drift wheels Have more 16" wheels and tyres if buyer wants. No swaps, no offers. Had this car for more than one year, done 8 drift days and has flawlessly performed so far, never missed a beat. Only selling to upgrade to a better specced car. {} {} {} {} {} {} {} {} Car is located in MK46 and can be drifted at L2D's Rockingham drift days. Daniel
