BMW E36 (inc M3) and Z3 Front Camber Adjustment Kit reduced to £18 inc UK post Still got a few of these left, now reduced to £18 posted! The perfect basic and simple alternative to silly money BMW camber top mount plates! An economical way to get more camber, adjustable in 4 steps from stock to maximum. Maximum will vary on different cars (depends on ride height, which top mounts and TCA bush you are running and what offset wheels you have), but expect up to around 3-4 degrees, less if required by making adjustments as explained in the instructions (takes about 5 mins to make the adjustments). Also adds track in 2.5mm increments per side, up to a max of 15mm total added track! This effectively increasing front anti-roll rate (like fitting an uprated anti-roll bar) and adds stability as an added bonus. Very simple kit and super easy to fit, works essentially the exact same way for camber & track as a Negative Camber Roll Centre Adjuster (NCRCA) does on an AE86, spacing the base of the strut for wider lower track (top of wheel will tilt inward obviously) and more camber. Kit includes full instructions and new 12.9 grade hardware. Great for drift & track or even show cars needing to tuck wider/lower offset wheels under the arches. £25 posted Still got a few of these left, now reduced to £18 posted!
Yeah and these will work WITH Evo top mounts (either in stock orientation or reversed) to add even more camber.
just got a set of these,will get pics up for you soon will of both the diff-diff kit and evo top mounts for combined cambersss
Cheers mate, yours should be there Monday hopefully You certainly won't be short of camber now... maybe go for the middle setting on the bolts (ie 2 shims instead of 3) in combination with your reversed Evo mounts?
Very interested in these, is Ren still getting pics up of how they sit on his car combined with the evo top mounts?
Tom - I'm sure Mr Ren will get a pic up when he can, think he's busy with engines at the moment though... To all who have sent payments - kits sent today. Instructions all emailed out too Rich - payment received today will get your kits out tomorrow Cheers Still plenty available.
hellos chaps - sorry i havent fitted them to the m3 at the moment as its awaiting an engine swap and i havent bothered my arse! sorry
Bump. Cheapest front camber around for E36's and easier to fit and better results than expensive camber plates!! Kits ready to go anywhere in the world...
Yep still available, cheapest, simplest and bestest front camber mod ever! We fitted one in 2 minutes per side the other day too... a personal best.
