The car can be delivered BMW E36 DRIFT SPEC Engine: Samsonas motorsport built M50B31 Stroker Turbo Power: 650HP Torque: 897 Nm Crankcase: Rebuilt with M54 Crankshaft JE Pistons,Total seal piston Rings,Pauter rods, ACL Crank and rod race bearings {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} S54B32 sump with VAC motorsport high volume oil pump ARP head and main studs. Hea:d Fully ported. Bigger race valves, Athena O-ring Gasket , Race springs Camshafts: Dynamic Debilas turbo cams 283/263 Cooling system: Mishimoto big radiator in trank modified by JFP 2-Spall electric cooling fans. Craig Devies electric cooling pump with digital controller Oil: Miller oil 10w60 Fuel system: Race fuel tank built in saloon left side Low pressure pump-Bosch 044 High pressure pumps 2* DW400 Fuel Injectors Bosch 1300ccc Nuke performance fuel rail Nuke performance high flow fuel filter Fuel pressure regulator A1000 ECU:VEMS by special Tuning Valdas Komutochuevato Fuel:E85 Exhaust:Exhaust custom manifold 2*3:1-2:1 by JFP TUNING Turbo:Precision ball bearing PT6266 Gen 2 Westgate :Precision 60mm Exhaust system: 4"By JFP tuning Intake: Piping by JFP tuning Intake manifold: Custom Aluminium by JFP tuning Cooler:Autobah custom design by JFPTuning Air filter :K&N Accufab 70 mm throttle body Drivetrain:BMW ZF 5 gears (or for additional money Samsonas sequintal 5gears) Clutch: Clutch Master 800 series 2 twin disck and flywheel Prop shaft and drive shafts: BMW M3 E36 S52B32 Differential: Type 210 LSD 3,64 Samsonas rebuild in 2017 and race set Tilton pedal block 800 series Body:BMW E36 Coupe 1996 Roll cage: Shimkus Racing Plastic works :HKG motorsport individual body kit with special metallic Chameleon paint Metal works: JFP Tuning Electric works :HGK motorsport Glazing :Windshield glass and polycarbonate Suspension: Samsonas motorsport (Ohlins) 2way coilovers front and aft Lock kit: SLR Super angle kit from USA FD Legal Brakes: Rear- M3 E36.with additional supports from Z350 Nismo for Hand brake Front -M3 E36 brakes Brake hoses :Wisefab full kit Handbrake: HYZ Interior: Sabelt and Sparco seats Belts: Sabelt & Schroth Shifter: custom JFP Tuning Dashboard :E36 Flaked Pedal box:Tilton 800-Series Gauges: Autometer: Oil ,water,voltage fuel pressure ,oil pressure, oil temperature,Water temperature {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {}
Good evening. What a fantastic specification on your engine. To avoid messing you round how much is the car please. Regards Steve
