Bmw e39 535i drift / road car
Thread in 'Drift cars for sale' started by Stevey, Sep 15, 2015.
  1. Stevey
    Stevey Member
    Bournemouth
    Time has come to sell my e39 drift car , Ive built this up over last 3 years and tbh i dont really wanna sell but i need to get the money to put towards a deposit and drift cars and saving dont seem to work at the same time.
    Car started life as a Manual 1998 535i se 5 series and the mix of a 530i Mport 2001 that i mixed the parts to get the best from both. its had plenty of work done to it to make it a very easy car to drift. With it being the smaller v8 i fitted a low ratio diff from a 530i auto ( i think ) i cant remember the exact ratio but this car has a very low ratio setup on it. top speed is around 130 which can make it a bit of a pain on the motorway as your pretty high up in the rev's on a run. But round a track its perfect.
    Spec
    Suspension & Brakes
    Hsd Coilovers (Around 5k)
    Modified front knuckles (specially made)
    Custom lockstops to stop over center
    Powerflex Black series Front lower tie bar to chassis
    M sport brakes fitted on front ( much bigger than stock )
    Low ratio diff 3.46 i believe
    Recent 4 wheel laser alignment (drift setup)
    Engine
    Stock engine
    Spark plugs and oil changed 5k ago
    Gen Bmw camshaft sensor changed 4 months ago
    52mm Alloy rad fitted
    Electronic thermostat fan control
    1 x Large electric fan (switch inside)
    Rocker cover gaskets changed 5k ago
    Gen Bmw Thermostat 5k ago
    Standard exhaust had silencers and tip changed (Cats left in otherwise would be too loud)
    Wheels and tires
    17 x 8.5j Rondell 58 ( could do with a minor refurb ) or Borbet A 17 x 8.5j with 4 very good tyres
    20mm Hubcentric front spacers
    50mm Hubcentric superforma rear spacers
    4 x yoko parada spec 2 tyres 205/40/17 ( 2 almost brand new and 2 5k ago )
    Interior
    2 x Cobra Imola seats ( Out of fia ) very good condition
    obp hydro handbrake (extra big handbrake , clears the dash)
    Driftworks hydro lines
    Steering boss
    Nardi steering wheel (not sure if its real as i got it with another car so assume its a copy to be safe)
    2 x 3 inch TRS 4 point harness ( Out of fia )
    Stripped out rear and boot
    Bootlid lightened
    Switch for fan
    Exterior
    Bolt on rear arches
    Rear wings cut out bent up and welded together (Sealed to stop rust)
    M sport front and rear bumpers (some damage and repairs done to them
    Facelift front lights and bonnet
    Repainted in a matt grey
    Front and rear bumper quick release things (forgotten what they are called)
    Sum it up this is a very capable drift car , Has no problem drifting every other week . very reliable engine and suspension set-up, been drifting it for 2 years pretty much at least once a month with no problems and car is mot'd for 11 months i believe
    Bad bits
    Paint work is ok nothing special but if you come expecting a show car you will be disappointed
    Both rear jacking points have been cut out and had plates welded in . Never been to much of a issue as i use the diff when drifting. Car has covered 170,000 miles but you wouldn't know it to drive it
    Spares
    If the car goes for close or the money i want i will include a entire front end (minus headlights) preface lift
    2 x spare diffs (1 x 535i manual diff , 1 x 530i Manual welded diff)
    5 x drift rims
    Money wise i was looking for around 3.5k which i think is fair with the spec and the manual box etc . I might be open to part ex for a decent jap daily plus cash my way . Car is Located in Bournemouth
    If i dont get much interest it will be broken for parts , Such a shame if i have to break it
    - - - Updated - - -
    PS Private Plate will not be sold with car , Will need 2 weeks to take it off
  2. 36skidder
    36skidder Member
    Fancy a deal with an s13 project?
  3. Stevey
    Stevey Member
    Bournemouth
    Now breaking for parts
  4. StenderNL
    StenderNL Member
    how much voor complete engine swap with box and loom and stuff
  5. lewy-linto
    lewy-linto New Member
    How much for the Hydro and Nardi mate?
  6. smithylee
    smithylee Member
    :( shame to see this being broken, always loved this car from when Graham had it
  7. Stevey
    Stevey Member
    Bournemouth
    Probably a different car i build this up from a basic spec one
  8. Stevey
    Stevey Member
    Bournemouth
    Sorry bud keeping both for next toy
  9. havill
    havill New Member
    How much would you want for the modified front knuckles?
  10. Stevey
    Stevey Member
    Bournemouth
    Pm,d Everybody that asked questions will be starting to break it this month
  11. V12
    V12 Member
    Would you sell the steering wheel hub? or give me a hint where to buy one?
  12. Stevey
    Stevey Member
    Bournemouth
    Sent you a PM regarding Hub
