Selling my below 2 year project Completely finished and tested on track Can be seen on Facebook- Davis Dergacs So its originally 318i compact converted to 4.0 V8 manual All bits at car: Engine-M60B40 Gearbox- 5 speed ZF manual gearbox with crank sensor so can be used with M62 3.5 engine as well Wisefab Formula Drift approved lock kit X5 manifolds Custom made subframe and sump Relocated oil pump Custom made uj joint made for V8 conversation Propshafts with 3.15 diff and large shafts Fully polybushed subframe-Strongflex PO performance camber arms and hydraulic hand break PMC short shifter Brand new clutch from e39 M5 Lightweight single mass flywheel-6.9kg All wiring been removed and replace only with necessary ones:starts on bottom,cut off with switch Gauges coolant temp Switch for wiper blades,cooling fan,fuel pump,ignition HSD front adjustable shocks with top mounts Big radiator with temperature sensor fitted Sparco seat with brackets and seat belts Custom made dashboard and fuse box All round Macralon windows,driver one with slide opening Brided fuel lines Brided power steering lines Stainless steel exhaust with x pipe and MIJ silencers And many more thing done All parts are new and best quality. Needs proper colour spray and roll cage for competition Everything works as it should Drives mad,full of power,handles brilliant All details in https://m.ebay.co.uk/itm/Bmw-e46-co...176116?hash=item467c4dad34:g:yXcAAOSw8Sta8u7W £6k ono As can see spent fortune on this project over past 2 years and lot of time Not answering on silly questions Viewing available Contact me on 07761790046 Located Birmingham {} {} {} {} {} {} {}
