BMW: List of 210mm cases that came with 3.91 or 4.10
Thread in 'Technical Questions' started by richATTK, Apr 30, 2013.
  1. richATTK
    richATTK New Member
    edit: updated list.
    I'm looking to diff options for me E46 M3. I figure I could ask some guys across the pond, it seems slightly more common to drift these over there than here in the States.
    I've been looking around for diff options. I've found lots of old threads, I just want to ask if anyone has a DEFINITE/exact/updated list of what BM cars came with a large, 210 case (with 8 bolts on each side of case, not 6) with 3.91 or even 4.10 gears. I'd like to try to score a cheap diff and swap over the gears. If it's an open diff, weld it and see how I like it compared to my stock M-Variable Diff.
    This is what I've found, please confirm or correct me:
    Large 210mm Cases (any gearing)
    -E24 M6
    -E31 850 (auto has 3.64)
    -E34 M5 before 6/94= 3.91
    -E36 Euro (w/3.2l) M3)
    -E38 730, 740 (V8s), 750 (v12)
    -E39 535, 540, M5 (all V8)
    as I said before, I'm not 100% sure on these, it's just info I've gathered from the last couple days, any help is appreciated. Thanks guys!
    #1 richATTK, Apr 30, 2013
  2. richATTK
    richATTK New Member
  3. jankes
    jankes Member
    e34 M5 has 3.9 ratio mate but not sure if its from 3.6 or 3.8litre model
  4. alexfalk
    alexfalk Member
    The only e34 diffs with 3,91 gear ratio are m5 up to 6/94 and 535i automatic with m30 post 9/89.
    540 is 2,93.
  5. richATTK
    richATTK New Member
    Thanks and these are all the large 210mm cases right? Mostly everything I find is for the medium 188 case
  6. alexfalk
    alexfalk Member
    Yes those are 210. From what i know only the 3,2 m3 have 210 from the e36 chassi.
  7. richATTK
    richATTK New Member
    Yeah not many of them around here in the States. We got the 3.0 S50B30.
  8. Bolf
    Bolf Resident Nut Job.
    e39 540i is 2.81 , both manual and auto
    e38 740i is 2.91 i think and the sports are 3.15
  9. richATTK
    richATTK New Member
    Thanks, guys. I've updated the list. The search goes on.....
  10. superclarkey
    superclarkey DORITECH MOTORSPORT
    Fairly sure 4.1 is a motorsport only diff, didn't think you could get a 210mm in 4.1 off the line.
  11. Bolf
    One of the x5's are 4.1 iirc
  12. DaveM
    DaveM flickwandoops
  13. superclarkey
    Yeah its a 4.1 but I didn't think it was a 210mm diff?
  14. richATTK
    richATTK New Member
    Yeah a 3l sounds like it would be a medium, 188 case.
    #14 richATTK, May 9, 2013
