BN Sports JZX110 450hp
Thread in 'Drift cars for sale' started by -Marc-, Jun 18, 2017.
  1. -Marc-
    -Marc- -JZX-
    west wales
    Finally come to the conclusion that I have zero time for this, literally driven it a handful of times since mapping 6 months ago.
    The car itself is on around 75k miles and started life as an auto (properly converted in Japan before export). Most parts fitted are brand new, high quality and fucking expensive. The car was mapped by Greg at Protuner making just shy of 450hp, using the CT15 at 1.45 bar and it's super responsive as you'd expect.
    Spec below though I'm sure I'll miss bits.
    Engine/Trans':
    Hybrid CT15 with larger inconel wheels and shaft (will take 1.5bar)
    Turbosmart actuator
    Kazama F1 manifold
    Sard 850cc
    Sard fuel rail
    Sard 295lph pump
    Aeromotive FPR
    HKS filter
    Greddy FMIC
    Greddy rad'
    Profec (new style) set at 1.45bar
    HPI decat/elbow
    3" oval exhaust made from Part Shop Max tube
    R154 - Redline oil
    Exedy Compe-D hyper twin clutch - sub 500 miles on this!
    HKS F-Con VPro (3.1)
    Handling/foot work:
    CST Zero coilovers - Swift springs 18/14kg
    Uras pillow ball bushed front tension rods
    JIC Magic rods/oem ends
    Ikeya Formula front upper camber arm
    Front spindles dropped 25mm, offset (increasing camber) and braced. Solves the turret/camber arm contact issue.
    KTS 25mm RCA's
    Front 15mm bolt on hubcentric spacer
    Ikeya Formula rear lower arm
    Ikeya Formula rear toe arm
    Ikeya Formula rear traction arm
    Ikeya Formula subframe locking collars
    Weld rear subframe bush collars
    Solid front diff mounts
    Tomei 2 way - Redline oil
    SuperPro poly bush for rear traction rod, hub side.
    Figs engineering spherical bearing for rear lower arm, hub side
    Hey man style knuckles - not fitted.
    Interior:
    Nardi 350mm deep corn wheel
    Bride Zieg iii
    Bride rail
    Greddy shift knob
    New style Profec
    Exterior:
    Full genuine BN sports aero
    BN Sports bonnet - came off the Magician 110!
    Ganador mirrors
    Kazama roof wing
    Kouki front lights
    Kouki rear lights
    Kouki boot trim
    Full respray in Mazda sparkling mica black
    Wheels:
    These may or may not come with the car but I have other decent wheels to put on - will discuss with potential buyer.
    SSR Minerva: F 18x10 +24/225.40's R 19x10.5 +18/245.35
    Plate isn't included and also not for sale.
    Price: £15,000
    No PX unless you have e9x m3 or v10 m5/6.
    No bullshit promises.
    Check my build thread for proper details or contact me if you're serious.
    Marc.
    20160907_171515.
    #1 -Marc-, Jun 18, 2017
    • Like Like x 2
  2. -Marc-
    -Marc- -JZX-
    west wales
    Sorry for lack of pictures, I have no internet at home so doing this all from my phone.
    20160907_171555.
  3. -Marc-
    -Marc- -JZX-
    west wales
    20170619_082736. 20170427_203322. 20170319_094601.
  4. -Marc-
    -Marc- -JZX-
    west wales
  5. hermit
    hermit Member
    Bump for one of the nicest jzx110's out there bud
    Is that a tablet you are running where the sat nav screen is with a Defi smart meter?
  6. -Marc-
    -Marc- -JZX-
    west wales
    Thanks man.
    It is, only half way there so far, just haven't had time to make it work properly. Everything I have including the tablet will come with the car mind.
  7. brian383
    brian383 Active Member
    northern ireland
    how did u do the screen with the gauges looks class
  8. -Marc-
    -Marc- -JZX-
    west wales
    Bump.
    Please stop PM'ing unless you actually intend to buy it, it's pointless and fucking annoying.
  9. Mehmet
    Mehmet Member
    London
    Lovely car,
    Good luck dude, i got nothing but shit from timewasters/dreamers so i just removed from sale.
