right the time has come, my rb25det s14 is up for sale, ill probably regret this but mea onwards and upwards n all that, this car is a beast, hard as fuck i can link the whole of lydden hill in this n im petty shit but the power and handling is perfect on this , its no show car tho the kit is used located in kent DRIVETRAIN the engine has done less than 1500 miles from rebuild ( done by myself ) so basiclly just run in the engine was fully stripped cleaned, block was decked /skimmed, crank checked and polished, new front and rear main seals block painted sump ainted all new genuin gaskets used etc engine is spot on and with only 1500 miles on it runs sweet as a nut rb25det engine full head rebuild, valves lapped, head skimmed and pressure tested, new valve stem oil seals acl mains and big ends less than 1500 miles old cometic 1.3mm headgasket water pump less than 1500 miles old ally rad twin fans lightend flywheel puk clutch ( like new ) cambelt kit 1500 miles old large airfilter gtr front mount cooler custom one peace alluminium propshaft full 3 inch exhaust system (staright through) 3 inch flexi in decat pipe walbro 255 intake pump engine bay has been fully stich welded and painted candy green INTERIOR hidden ingition kill switch apexi boost gauge large rev counter with external shift light rms oil pressure gauge x1 trs harnesses magnum fisxed back drivers seat rally desighn passenger seat dished steering wheel battery in car via good quality battery cable rescent new car battery custom switch/fuse panel custom fire wall CHASSIS rota svn 9 j (215/40r18) up front 10j on the rears (225/40r18) large 4 to 5 stud spacers yellow stuff rear pads apex coilovers welded an auto diff japspeed short shift na rear subframe (wider than norm) skyline front brake setup custom gearbox mount rb25det gearbox good strong box modified front hub nuckles extended lower front arms 25mm fitted with dw bushes rear droplink bushes poly flex apex subframe locking collars dw rack spacers front sturt brace full body kit rocket bunny rear spoiler,,, genuin carbon fire bonnet few cracks but mea light as fuck n looks baddasss front looms have been cut extended and re wrapped out of harms way the under side has been completed cleaned and under seal,( there was no rust on it before i just wanted it to stay that way ) bumpers and sides skirts ,the prop, full exhaust and heat shields were removed pria to undersealing, so it will be good a rot free for some time to come the car is tatty end of the day its a skid car and it gets used hard, wiper motor only has two speeds, front windscreen has rather large crack in it never bothered me tho , but if your after a car with good power good looks and amazing handling this is for you, im no great driver by far but i got a semi pro liscence in it a few weeks ago so it cant be that bad, it did have a cage fitted but no longer ther but holes in dash and floor are ther ready if u want to add one serious people only im in no great rush to sell and ill prob want to buy it back when it does go lol i will be fitting a good nsr light before sale the car has just had all oils replaced with brand new fluids gearbox oil replaced castrol diff oil replaced castrol coolant flush and change 50/50 mix coolant and water engine oil and filter mobil 1 10w60 brake fluid changed - vacum bled car has tax and long mot £4995 as it is £4795 as it is with wheels and it will have volks rays 17 inch shiny wheels fitted with good tyres all round pm me if you would like any more info or pics s14 by James Tremain, on Flickr
BUUUUMMMMPPPP for a seriously nice car, will be sad to see it go but the new owner will not be disapointed
Cheers boys I no ill miss it but already got my car for next year so this has to go Cash only no swaps
ive come back to look at this about 5 times now since you posted it... trying to wreck my brain on how to raise the cash.. lol too many cars, not enough cash
haha i no the feeling mate im always perving at other people cars lol this may be going to sweden folks
Dude, this was going great at the bdc licencing! Why sell it now, what you got tucked up your sleeve? @reeperR32, if you wanna free up some cash to buy this then message me about ya e30 v8 (sorry to hijack) Free bump for a quality car
video as requested of idleing and revs to show no missfiring rattle etc idles well slightly fluctuates but nothing over the norm
Sorry to hijack again Harry, but ReeperR32, empty your inbox. Harry, i've txt you about what plans i have, we'll discuss by txt
