Hiya, i am selling my brand new tv as i have just had a load of money stolen from myself and need to raise some cash quick to carry on with my r32 project. Its in black and has the bracket kit with it still in box unopened. It is totally unmarked and in as new condition being only a week old. Ihave used the tv litllery for about an hour. With the bracket cost me £450 a week ago Will sell for £350 I may consider a swap for r32 gtst bits. Cheers guys
Cool thanks for info Ian U just remove the front drive shafts and the shaft that comes from the transfer box, and remove the abs fuse I believe?
I have a GTS4 and I removed the shafts leaving all the cup parts in, apart from the passenger diff side, where there's no oil seal. If you don't leave the cup parts in at the wheel end the wheels could fall off! With the front prop I am not 100% but I think you can unbolt the front end and pull the rear end out and bodge something up to stop crap getting in the opening. Tuners often remove the front prop when dynoing 4wd cars with no worries. Once the shafts are out of the way you can do some steering lock mods to gain a bit more, one 3mm spacer each side will be about your limit. You can see my GTS4 thread here. ABS fuse, top left under the drivers side dash is the Front Diff/ ABS fuse, pull it as you say as it's actually safer without the ABS on when drifting. Say hi if you come to DWYB. I hope this helps... Ian.
Cheers for the info Ian, mines already been done tho before I brought the car yea I will defo be at some dwyb days as soon as Iv finished the makeover on her and I get my d/l back! Thanks again mate! Come on guys must be someone wants a nice new telly! Bumpitybump!
