Brand new set of 4, 6, or 8 TRE 840cc (80lb) injectors
Thread in 'Parts for sale' started by Sunrise, Feb 5, 2018.
  1. Sunrise
    Sunrise Member
    Set of 4, 6, or 8 TRE 80LB (840cc at 48psi) EV6/EV14/USCAR Stubby Pico Fuel Injectors.
    Originally bought from TRE in the USA a few months ago for a V8 project, but I'm in need of some bigger injectors and have bought more from TRE, so these are for sale brand new and unused (and minus the import duty I had to pay).
    Either available as a couple of sets of 4 injectors, one set of 6 injectors (plus 2 spares!) or a single set of 8 injectors.
    hXvbtJK.
    Prices:
    • Set of 4 is £90 posted
    • Set of 6 or 8 is £160 posted
    Spec below, any questions please ask.
    Spec below:
    Condition: 100% BRAND NEW
    Typical Flow Rate in CC per minute: 840 CC/min @ 48 PSI
    Typical Flow Rate in LB per hour: 80 LBS/HR @ 48 PSI
    Typical Flow Rate in CC per minute: 800 CC/min @ 43.5 PSI
    Typical Flow Rate in LB per hour: 76 LBS/HR @ 43.5 PSI
    Actual flow rate of your injectors may vary, but will be matched together
    Resistance: 10.0 ohms (High Impedance, High Resistance)
    Voltage: 8-15 Volts, nominal 13.5 Volts
    Amperage: 10.0 Amps
    Pressure: Min 30 PSIG / Max 100 PSIG
    Spacers/O-rings Included: YES, on the injectors
    Fuel Delivery: Upgraded single fuel delivery nozzle for superior fuel atomization
    Spray Pattern: 26 Degree Spray Cone
    Electrical connector type: EV6 / EV14 / USCAR Oval Plug
    Body Design: Compact, composite plastic
    E85 Compatible: Yes
    Offset: 0.065ms
    Turn on time @ 14VDC: 1.3ms
    Turn off time: 0.7ms @ 600KPa
    Series: DEKA 5 ( DEKA V )
    Overall Length: 2 inches, 48 mm
    Diameter: 19 mm
    Orings: Top and bottom 14.5 mm
    #1 Sunrise, Feb 5, 2018
  2. Sunrise
    Sunrise Member
    Bump.
    Offers accepted.
  3. crazyae86
    crazyae86 Well-Known Member
    can this works on sr20det ??
  4. Sunrise
    Sunrise Member
    Standard SR20 injectors are side feed, these are top feed.
    If you were to fit a top feed fuel rail they would work, you'd also need to solder on new injector plugs connectors.
  5. Sunrise
    Sunrise Member
    Bump.
    Not sure if I've missed something from my ad. Would have thought these would have gone by now.
  6. Leigh ireland
    Leigh ireland Member
  7. Sunrise
    Sunrise Member
  8. Sunrise
    Sunrise Member
    Price drop
    • Set of 4 is £75 posted
    • Set of 6 or 8 is £140 posted
  9. Andrew1985
    Andrew1985 Member
  10. Sunrise
    Sunrise Member
    Price drop
    • Set of 4 is £60 posted
    • Set of 6 or 8 is £110 posted
