BREAKING Big spec BDC s13
Thread in 'Parts for sale' started by jaksey-rob, May 24, 2016.
  1. jaksey-rob
    jaksey-rob Member
    I've decided to break my s13 200sx comp car that had a ls1 v8 conversion in,
    Bodywork.
    Fibreglass doors. £300
    Super made kit needs a bit of repair to front and rear bumper £200
    Koguchi front and rear fenders, comes with a brand new front wing as a spare £200
    Carbon rear boot with plastics 4 performance lexan window, has has got riv nuts in for the spoiler £250
    Wangnam spoiler £100
    Nismo bonnet vent on standard bonnet £50
    Genuine kouki lights with rare Kevlar centre section £400
    Front lexan windows £150 if I can get the rears out ok £100
    Chassis
    Bare Shell strapped to a pallet, Overall good condition had some rust repairs/ no crash damage, Transmission tunnel enlarged to bdc specs for t56 gearbox
    Front strut rollcage bar welded to turrets and gusset to firewall
    Front tubbed, and bits removed for wheel clearance for tdp lock kit
    Front arms braced, Rear firewall, with log book and private plate k200sxf, £250
    Fabricage bolt in roll cage £500
    Rear subframe powder coated silver with solid bushes £100
    Kazz 2 way skyline diff (I think 4.1 need to check) with 5 stud driveshafts £600
    Suspension
    hsd coilovers £400
    Front Tdp lock kit with nearly another whole setup included as spares (basically 2 kits), I think the only thing I haven't got is spare top mounts/ just put new tein rods and new updated rose joints on as well £1500
    Part shop max steering rack relocation bushes for s13 rack £50
    Rear s13 wise fab kit £1000
    Rear cusco strut brace £30
    Front and rear 5 stud wheel bearings £200
    Brakes
    330mm skyline front brake conversion £220
    Rear skyline brake setup with twin calipers 250
    Obp hydro with resovour and cylinder £100
    Obp pedal box cable throttle £450 I have the throttle sensor for fly by wire brand new £200
    All brake lines stainless braided £150
    Wheels
    Image 3 piece splits £800
    Front 17x9 et0 I believe, tyres Yokohama 215/40 the perfect size for the tdp kit full lock no touching anywhere
    Rear 17x10 not sure on offset maybe et15 sits on 25mm rear spacers and sits well in the +70mm rear fenders
    Inside
    Stack dash with sensors £700
    Custom aluminium kill switch box with cut off £40
    Plumbed in fire extinguisher £80
    Red battery box £30
    Ls1 conversion parts for s13
    Front subframe modded for using standard ls1 front sump, Steering rack moved foward
    Custom Steering column moved higher to clear starter, give more room for manifolds and pedal box also lengthened to sit further back.
    Engine mounts
    Gearbox mounts
    Custom prop for non abs diff, might fit abs but haven't tried
    Custom made manifolds and exhaust
    Small starter motor
    Custom power steering lines and oil cooler
    £1200 for all bits to convert to ls1
    Sr20 Aluminium rad with twin kenlow fans with twin stage relays/sensors in top rad pipe £400
    If your interested add me on Facebook, Robin Jakes and I'll send you some pics of what you need
  2. Drifttrader
    Drifttrader Member
    How much for it rolling?
  3. ianlea73
    ianlea73 Well-Known Member
    Bristol
    Not on facebook so could you stick a few pics on here. Also what's your location?
  4. jaksey-rob
    jaksey-rob Member
    I had it up for £7500 rolling but bits are starting to sell already
    - - - Updated - - -
    Kent, what pics do you want pm me your email and I'll email them over
  5. daisyD
    daisyD New Member
    I'd be interested in the doors if you weren't so far. Shame
  6. haza88
    haza88 Active Member
    ya mumas
    also not on facebook
    pics please
