Breaking Forged Sr20det S13, Sparco, BGW, HSD, T28R, 5 stud, Stage 1a ECU & more
Thread in 'Parts for sale' started by Laurence B, Aug 13, 2015.
  1. Laurence B
    Laurence B Member
    Breaking Forged Sr20det S13, FMIC, Sparco, HSDs, 50 & 30mm 5x114 Spacers & more
    Breaking the car due to my friend going to Uni and not having the time or funds to carry on with it.
    This is a complete car, shell has been welded up and it was undersealed last year. If there are any other s13 parts you are after you are after drop me a pm as i most probably have them.
    Engine & Turbo
    SR20det tall block rebuilt a few 1000 miles ago, run in properly on stock boost, good compression over all 4.
    Sr20det Specs:
    Rocker Arm Stoppers
    Refreshed Head (new stem seals, valves lapped in etc)
    Cosworth Headgasket
    ARP Headstuds
    Weisco 86.5mm pistons
    Arrow Con Rods
    Reground Crack & oversized ACL bearings
    ACL Main Cap Studs
    Baffled Sump
    Bad Bits: slight vvt rattle on start up, I have a spare vvt sprocket I can include.
    Slight seep from front cover (All SRs do it)
    Slight seep from rocker cover gasket (Can supply a brand new one)
    I'll get pictures up later, and a video of it running and compression test results.
    £1000ono
    T28r
    Bought from Garage D a year ago off a low mileage s15, boosts spot on. No up and down play and minimal if any side to side play SOLD
    Sr20det FMIC & pipework setup, Comes with tabs to bolt straight to an s13 will fit s14/s14a just need to make new tabs, Apex intercooler pipework with silicone hoses.
    Nipple welded onto hotside pipework for boost controller/gauge take off. Metal Pipe for standard dump valve pipework cut off and plated - TIG'd on, on the cold side pipework.
    Engine bay pipework has been powdercoated black. £100
    Suspension & Brakes
    HSD Dualtech coilovers - done a few 1000 miles, in good working order, no leaks or noises - £380ono
    [​IMG][/url]
    Whiteline Anti Roll bars, Front and rear, paint has flaked off in places - £150
    Full set of rose jointed adjustable arms. Rose joints are a bit squeaky - £120 for all 4
    Solid Bushed Rear Subframe - £50
    S14 Front calipers include Discs, Pads & Braided lines. Discs have slight lip and pads are around 40% worn. - £80
    S14 5 stud front knuckles, bearings & lower arms - SOLD
    Electronics
    S13 - S14a Black top SR20det engine loom. All plugs in good condition, Loom was bought from garage d and spliced into an s13 loom by me. In good working order, all plugs work etc.£100ono
    S14a Stage 1a Horsham Developments ECU - SOLD
    Gizzmo IBC Electronic Boost Controller, comes all wiring, solenoid & vacuum hose, in full working order - SOLD
    Exterior
    Rocket Bunny s13 front bumper, not a genuine one, fits well but has a crack along the bottom, not visible when fitted -£50
    Fiberglass rear bumper, unknown make, few cracks, easily repairable, see picture below -£50
    Sideskirts, unknown make, bit battered cracked in a few places and a few bits missing. - £30
    BGW, in good condition risers have a bit of paint flaking off but nothing too noticeable can be seen in picture below - SOLD
    S13 complete headlight unit o/s & n/s. Both in perfect working order. - £30 each
    S13 Bootlid, No rust. Has around 5 holes for a wing in it. £60ono
    Interior
    S body Driftworks Super Low Drivers Side Seat Subframe - SOLD
    Sparco Rev Bucket seat, has alot of holes in the seat cushion due to not being covered properly whilst shell was being welded, few tears elsewhere on the seat. Overall good solid seat.
    price reflects condition - £60
    LUKE 5 point harness - £30
    Standard S13 clocks on 85k - £20
    Gearstick Surround with mint condition leather gaiter, 3 holes drilled for switches - £15
    Wheels & Spacers
    Set of 17x9.5 Brenz Wheels, Some minor kerbing. Front tyres have loads of life. rears could do with replacing. £450.
    50mm 5x114.3 Hubcentric Spacers £80ono
    30mm 5x114.3 Hubcentric Spacers £80ono
    I also have all stock s13 parts such as all body panels,interior looms, dash,clocks, trims, bmc, clutch mc, prop,etc etc.
    Will get pictures up in the next few days. Drop me a pm with your mobile number or email as i'll be able to get pictures sent to you quicker.
    Located in Farnham, Surrey
    I can post most parts apart from engine and fiberglass bits.
    #1 Laurence B, Aug 13, 2015
  2. Tobrom
    Tobrom New Member
    Sweden
    Can you send me pictures on S14 Front calipers, Discs & pads? Pm me
  3. nismolad
    nismolad New Member
    Ireland
  4. miffy
    miffy Member
    Side skirts ?
  5. enginebuilder
    enginebuilder Active Member
    swansea
    Can you confirm bgw 54" 57" or larger. Pm!!
  6. Laurence B
    Laurence B Member
  7. jackg16
    jackg16 Member
    Stoke on trent
    would you courier the seat?
  8. Laurence B
    Laurence B Member
    Would prefer not too, post updated with more pics.
  9. Laurence B
    Laurence B Member
  10. dshar
    dshar New Member
  11. MAX.T
    MAX.T Member
    Manchester
    interested front 14 brakes. Would you post them to Manchester?
  12. kev200sx
    kev200sx Member
    Andover,Hampshire
    Any Sr gearbox for sale? Condition and price please
  13. ian_edintyre
    ian_edintyre New Member
    Edinburgh
    Seriously interested in the t28r - cash waiting.
    drop me a message on 07732090031 if it's still available!
  14. miffy
    miffy Member
    Would you post the skirts ?
  15. steviechaplin
    steviechaplin Member
    Any pics of rb bumper and crack? Cheers
  16. Laurence B
    Laurence B Member
    More pictures added
  17. Tian:p
    Tian:p New Member
    Sweden
    Still got the s13-s14 loom?
  18. dmm
    dmm New Member
    Buckley, North Wales
    is engine still available?
  19. dmm
    dmm New Member
    Hi if engine is still for sale get in touch I need one urgently. May also take arb s and possibly the turbo too, cash waiting.
