All Needs to go. Taking offers on everything. Price dropped on all items. {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} R154 Manual conversion , Everything needed to convert any JZS161 to manual! - R154 gearbox with bellhousing from JZX90 Mk2 (has MC upgrades in box, but synchros could be refreshed) (quickshift fitted but has been adapted)(has weld shifter brass cup upgrade), Toyota fly and pressure (brand new genuine parts bought 3 years ago), performance puck plate supplied by Garage D (Ive had 460BHP and no slipping), pedals, modified propshaft, clutch master cyl, braided hose, propshaft disc to keep speedo working and handle handbrake conversion £3000 (TAKEN DEPOSIT) Supra rad conversion - electric fans included with shroud. Requires tags welding to bar below for mounting. Can be used with factory fan controller for air conditioning. Massively thicker than stock. Includes hoses. £100 SOLD Carbonetics 2 Way diff. Best mod ever on the car. Had this even with the autobox and is awesome. Due to carbon plates, no chattering at all at slow speeds or turning. Locks up a dream. Comes mounted in large case supra box which fits aristos. £700. SOLD LS400 Front caliper and disc conversion. Good life left in pads and discs. Comes with braided hoses, but would replace. £300. SOLD Full 3" exhaust system. Middle and rear silencer box. Raise as tight as possible. No joins except V band from downpipe so will need adapting at front to your exhaust connection. All hangers included. Single exit. Includes hanging tow strap with steel frame to fill in left hand side hole. Also has spark plug thread in tailpipe, video at bottom of page £180SOLD Flamer kit, Iridium plug with coil, transistor box and switchgear - £50 or free with exhaust. (SOLD) GS300 Rear Subframe. Eliminates rear wheel steer on the aristos. No shafts, diff or brakes - £100 (SOLD) Rear brake setup with discs and calipers and boxed new brake pads - £60 (SOLD) TTE Front lip, Genuine so plastic and not fiberglass. Was in a crash but fits fine and has never given a problem, however needs work and far from perfect. - £100 (SOLD) BC BR Coilovers. Stripped and greased these twice since owning the car so aren’t seized solid. Replaced the springs for higher 16 and 18kg springs which suit the cars weight much better. - £420 SOLD Aristo Genuine HID headlights. All work well. Self levelling error on the car so they don’t height adjust. One has a cracked housing and has silicone over it. Been like that when I bought the car. £80 SOLD Rear LED lights. Theyre tint filmed which can peel off. Includes the rear bootlid LED lights too. Indicators have LED bulbs fitted and the resistor pack to stop rapid flashing. £190 for all 4 Lexus grill, paint stripped back to chrome and has a Toyota emblem - £30 SOLD Front Lower arms with Super Pro Polyurethane bushes already fitted - £70 SOLD Front mounted intercooler and pipework - £100 SOLD TTE Front strut Brace one leg has cracked and holes in bar - Free with anything else SOLD TTE Rear Strut Brace - £50 SOLD Steering rack tie rods which have 5mm machined off allowing for more steering lock but not sacrificing thread penetration into steering rack. Have been used since photo . £50 SOLD Normal Handbrake conversion. Converts the pedal to a hand pull system through the factory drum brakes. - £70, for the lever, mount and cable to the existing joint under the car. Or Free with manual conversion SOLD GS300 climate control unit. Replaces the need for the Japanese headunit to control the aircon so you can fit a uk headunit. Plugs straight in - £40 SOLD 18” Rays Genome Drilled 10j et37 and 8.5j et20. They fit really really well. The rear tyres are 265/35/18 Federal 595 RSR and are a great balance for grip. Fronts are Yokohama Advan AD08r very good semi slick road tyres. Were £190 each just for tyres. - £850 DEPOSIT TAKEN JDM wind deflectors. All in good condition. One has silver rivets where the rest are black. All good condition. £60 SOLD GS300/Aristo double gauge holder Custom. Not been perfectly wrapped, could be sanded and sprayed - £60 (SOLD) Full Black leather interior - £300 Collection only. (SOLD) Aristo Rear Spoiler with working brake light - £ 100 SOLD SARD jet pump killer for fuel pump setup on aristos and jzs. Eliminates fuel surge on stock setups which occurred when over 300bhp. £50. SOLD http://www.sard.co.jp/after_eng/products/engine/jp_killer/jp_killer.html Any other Parts please let me know and Ill get a price together. Most parts are still on the car so don’t expect next day. Will most likely be a couple day lead time. All prices are subject to postage costs. Collection on certain parts and from PE19, St Neots. Far more parts available. Anything in build thread you see, let me know and I may still have it. VIDEOS = Exhaust noise Drag Race showing gearbox changes under load = Drifting showing diff performance = {}
Interested in the flamer kit Also when you did the gs300 subframe swap, did you re wire the ARS Ecu to fool it?
I have a ars sensor locked in the bypass position to go with subframe. Flamer kit I will offer to who ever buys exhaust first, then split
GS300 Rear Subframe. Eliminates rear wheel steer on the aristos. No shafts, diff or brakes - £100 Still here
