Breaking RB25DET S13 - Loads of goodies inside S13/14/15
Thread in 'Parts for sale' started by FreddieS, May 8, 2016.
  1. FreddieS
    FreddieS Active Member
    Godalming or Salisbury
  2. ianlea73
    ianlea73 Well-Known Member
    Bristol
    I'm doing an RB conversion. I already have engine,box & ecu. I have a top mount set up.
    Would your intercooler set up work with my set up?
    I'd also like the propshaft, radiator & exhaust.
    Could you send pics please & any engine bay pics you have to check out your set up?
  3. Kingk
    Kingk Member
    Essex
    Is it a bm57? If it is does it also have the connector plug from the loom?
  4. Jimbaw
    Jimbaw Member
    Penrith
    What injectors come with the Freddy plenum? And does it fit properly or does it need machining?
  5. FreddieS
    Stock sidefeeds, it fit fine and worked fine, had it skimmed when I got it and didnt have any issues with it.
  6. ianlea73
    Bristol
    Also rear subframe
  7. chodjinn
    chodjinn Active Member
    What steering arms were you using, geomaster ones? I'm after some that will work with geos as the extended ones I have are too short.
  8. FreddieS
    Was running relocated rack and longer inner tie rods. No geomaster rack spacers just longer inners. With 20mm lca's and geos it had plenty of adjustment on the inners
  9. ianlea73
    Bristol
    Trying again!!
  10. jayysmithyy
    jayysmithyy Member
    honiton
    Pics of bn front bumper?
  11. FreddieS
    Sorry bud, easier to message me then I see it.
    At the moment the complete RB setup is going as one, if he doesnt have it i'll let you know.
    Rear subframes available though, exhaust and radiator could be too but is collection only. Intercooler hot pipe would be in wrong place as it was fitted on a stock T3 midmount turbo, could easily be tweaked to fit though and would fit cold side if your running a greddy style plenum
  12. chodjinn
    You got the tie rods for sale?
  13. Chris 1986
    Chris 1986 Member
  14. FreddieS
    Deleted all sold items for list, open to offers on stuff within reason.
  15. [jay]
    [jay] Member
    Burton on Trent
  16. FreddieS
    Clear your inbox
  17. [jay]
    [jay] Member
    Burton on Trent
    Sorry, cleared now.
  18. Aj20
    Aj20 Member
    hull
    BN Front bumper any photos? ill take it if not too bad
  19. FreddieS
    Already sold.
  20. aj7
    aj7 New Member
    Is the relocated rack an S15 rack by any chance? If it is I'm interested
