Breaking turbo e46 lots of goodies
Thread in 'Parts for sale' started by supra_sideways, Sep 10, 2021.
  1. supra_sideways
    camborne cornwall
    Breaking turbo e46 drift build big spec
    M54b30 turbo engine
    K64 de comp plate and head gasket set fitted.
    Top mount manifold
    gt3576r (Chinese)
    44mm tial wastegate
    3” wing exit exhaust
    Disa valve delete with map sensor fitment
    650cc injectors
    High pressure fuel rail and pressure regulator.
    044 fuel pump
    Air pump delete
    Locked oil pump nut
    M52 power steering pump
    Ccv delete
    Looms striped back and simplified anything not needed been removed
    Comes with standard ms43 ecu
    £1200
    M54b30 engine swap.
    120k on the engine and zf gearbox.
    Mapped and immo delete ecu to run 2 lambda sensors, air pump delete and Maf delete, de cat tubular exhaust manifolds.
    Ccv delete ,locked oil pump nut £650
    530d 5 speed gearbox (big spline/big power) £250
    E46 330i maf x3 available £50
    E46 m3 clutch and flywheel £100
    E36 wisefab complete front wisefab £500
    E36 HSD monopros ture rear coil over setup
    £450
    E46 m3 lsd and complete rear end stripped ready for new bush’s £900
    E46 330i fully polybushed rear end 3.38 welded diff and adjustable camber arms £250
    330i brake upgrade £90
    Fibre factory over fenders (coupe) £300
    E46 Lexan windows all around coupe £150
    Custom chassis mount short shifter £40
    E36 engine mount arms £30
    E36/e46 polly bushed engine and gearbox mounts £40
    E46 m3 front bumper £50
    E46 m sport rear bumper £20
    Genuine e46 m3 wings drivers side damaged no rust £70
    E46 2.93 welded diff £30
    18x9 and 18x10 rota grid 5x120 £450
    18x9 et 20 5x120 rota torque pair £250
    18x9 et20 5x114 rota torque pair £250
    18x8 and 18x9 7 series deep dish style 32 wheels £400
    Jap style front bumper. Needs trimming £60
    18x8 rota reps £200
    Recaro glitter back bucket seat £300
    Omp wrap around seat large £200
    6 point harness 3” (pair) £100
    E36 polly bushed diff bushed £20
    Sr20 Jap speed alloy radiator £60
    Large front mount intercooler £50
    Led rear lights £50
    E46 coupe boot lid (gutted) with spoiler £40
    50mm hub centric spacers £60
    20mm hub centric spacers £30
    Adjustable camber arms £30
    Swirl pot with 2x 044 bosh pumps £80
    More pictures to follow or message me
    I’m in Redruth Cornwall but can post at cost.
    39431593-F182-4EE8-933D-FD5157D05A2A.
    06DD1662-1F7B-4C65-BC58-6F22CE275AC5.
    #1 supra_sideways, Sep 10, 2021
  2. J_W97
    J_W97 Member
    Stockport
    Are the adjustable camber arms still available?
  3. Aurneriel
    Aurneriel New Member
    united kingdom
    There ar eno photos
  4. supra_sideways
    camborne cornwall
    Yes they are
  5. Ben Anderson
    Ben Anderson New Member
    Edinburgh
    If you don't mind posting a bunch. of things to Scotland I might be interested in a few things. Give me a message on WhatsApp if you could on 07793614247 and just send everything to there. Thanks!
  6. Marcus Heinen
    Marcus Heinen New Member
    11 st philomenas crescent tower blarney cork
    Is front wisefab still available ?
  7. Sean.
    Sean. New Member
    I'm interested in som e parts mate can intend me ur number
  8. Josh Phillips
    Josh Phillips New Member
    Suffolk
    Could you send me some more info on the engine mate? Or send me your number
  9. Kaspa194
    Kaspa194 New Member
    Lithuania
    Do you still have m54 turbo engine?
  10. Saxskids
    Saxskids New Member
    Bedford
    Pm me I'm imterested in wisefab please pm me
  11. E30 Tommy
    E30 Tommy New Member
    Kent
    Is the engine still available
  12. Nilesh
    Nilesh New Member
    Loughborough
    Check PM
  13. alex.1
    alex.1 New Member
    shropshire
    I'm interested in the coilovers still for sale?
