Breather delete , 1JZ vvti
Thread in 'Technical Questions' started by Japtorque, Oct 9, 2019.
  1. Japtorque
    Japtorque Member
    KENT
    Hi,
    I assume I can delete this Breather that dumps oil back into the intake.
    I want to make sure before I weld it up ..
    My J-pipe breather goes to a catch can since I deleted the J-pipe .
    breather.
  2. Andy318ti
    Andy318ti Active Member
    Edinburgh-ish
    If you block it how's it ment to breath?
  3. Japtorque
    Japtorque Member
    KENT
    My J-pipe breather goes to a catch can since I deleted the J-pipe.
    the 2 cam covers are linked by a pipe,
    I think I answered my own question tbh.
  4. Andy318ti
    Edinburgh-ish
    I would weld two an fittings to the covers and run them to a catch can.
    For the abuse a drift car gets best to let it breath easy to avoid seal failures or weeping gaskets
  5. Japtorque
    Japtorque Member
    KENT
    yea i might do that while ive got em off , do you think an-6 should be enough?
  6. Andy318ti
    Edinburgh-ish
    -10 minimum I run -16 as it takes a 19mm hose without a huge restriction
