Bushes for I200
Thread in 'Technical Questions' started by m1key, Jan 20, 2012.
  1. m1key
    m1key Member
    In need of some parts for is200, i need the front lower arm bush (rear) on both sides lexus/toyota only sell the arm with bush, is there any where i can just get the bush from or off another car as iirc the JZX has some of the same suspension as the is200.
    Also need front passenger side damper mines fucked wheres the cheapest place for a replacement
    Mike
  2. Rossc0
    Rossc0 Diesel Skidder
    Powerflex for the bushes?
  3. 4_Stroke
    4_Stroke Member
    SuperPro, check on ebay
  4. m1key
    m1key Member
    I have just contacted Powerflex and they said they do not have any listed and asked if i could get a part number of anyone who has orderd previously.
    Thanks mike
  5. dale_b
    dale_b #DriftFactory
    I have a load of IS200 SuperPro bushes, I bought the entire set at great expense and never fitted it, iv sold the front traction rod bushes and a few of the other bushes but still got most of it.
    SuperPro make offset traction rod bushes, so you can increase caster, which is better for skidz:thumbs:
    Also, the traction rod bush is the same as jzx90/100/110 but the rods are different.
  6. dale_b
    These are the rods with SuperPro offset bushes....
  7. dale_b
    I also have these rear arms, powder coated Cusco blue and with SuperPro offset bushes to adjust Camber
  8. m1key
    m1key Member
    ok mate thank for the response these are the bushes needed
    How much matey and quickest delivery time dosent matter about anything extra as it is just to pass mot then the car is going
  9. dale_b
    In that case, find a pair from a scrap yard, I'll buy your old arms:thumbs:
  10. m1key
    m1key Member
    ok will let you know when it is done
