Ca18det crankshaft table
Thread in 'Other Chat' started by Waveydavey, Nov 21, 2014.
  1. Waveydavey
    Waveydavey Member
    Darlington/york
    When my Ca18det engine had enough and I went SR I decided to keep hold of all the parts to eventually build myself a table.
    As I had free access to a vapour blasting machine and a welder it made sense.
    Vapour blasted crankshaft
    Vapour blasted pistons and rods with ca18det tensioner bearing that so happens to fit perfeclty on the crankshaft.
    Spacers rods welded inplace so the bearing can be welded inplace
    This was then re-vapour blasted to remove the effects of the welding
    Top section fitted together.
    Flywheel base was then powder coated black, I drew out a template to send of to the glass company which was toughened and edges bevelled.
    And obviously as it's on a bearing the top spins.
    Unsure if this video link of the top spinning will work
    [video]http://instagram.com/p/sz-XKoLZJZ/?modal=true[/video]
    Thoughts on it?
  2. Retro - Slide
    Retro - Slide Member
    Nottingham
    Holy shit that's cool!
  3. Loopy_drifter
    Loopy_drifter Member
    Aberdeenshire
    This Exactly....
  4. Waveydavey
    Waveydavey Member
    Darlington/york
    Doe's the video work?
    Best use for a dead ca18det I guess, currently on building a toyota 3sge version.
