So i've just had my CA18DET fully rebuilt, first of all it was flooding cylinder 1 with tons of fuel, and only cylinder 1. Changed fuel injector and it started spraying evenly across all 4 again, great! turned it over to fire up, idles lumpy but doesn't die. As soon as i touch the throttle it dies instantly. Tried adjusting the timing/cas whilst it was idling but didn't seem to help. Ive never seen a car literally konk out as soon as the throttle is touched... I know this isn't much info, but i was just wondering if anyone else has had this issue? help me
Some extra info on the engine: Full 3 inch exhaust, fmic, air filter, stage 1 HD ecu, new bottom end, new stem seals, re lapped valves, 1.3 thicker head gasket, new crank bearings etc etc.
