CA18DET preservation society
Thread in 'Drifting Chat / Pictures / Videos' started by dori_wey, Nov 11, 2012.
  1. r3k1355
    r3k1355 Well-Known Member
    You really don't need the oil cooler for the diff, most people find theirs has never ran and just rip them off and block the pipes.
  2. THICK SOUP
    THICK SOUP Active Member
    Gospit, Hants
    +1 for this. When I did my S14 subframe swap I pulled all the diff cooler out. The pipes & cooler core where bone dry. I pulled the diff out of a mates S14 & the pipes actually had dust in them.
  3. lezbrucelee
    lezbrucelee Southwall Smokers
    Kent
    Sweet i wont bother putting it back then, 1 less ball ache.
  4. 1N5_N15
    1N5_N15 Member
    New Zealand
    Would a T04E be too much for a CA18?
    i.e. laggy or just plain too big?
  5. r3k1355
    There's lots of different sizes so you'd have to be more specific.
    None that will fit on the standard manifold tho.
  6. 1N5_N15
    1N5_N15 Member
    New Zealand
    I will borrow if off him and take some measurements, i have an aftermarket manifold with a t3 flange so it will bolt on
  7. adam-dorward
    adam-dorward Member
    Bournemouth
    Any1 use a bee r on there ca?
  8. Spanair
    Spanair Member
    Enfield, Middlesex
    I had one in my last S13
  9. adam-dorward
    adam-dorward Member
    Bournemouth
    Are they hard to fix and set up?
  10. SteveC200
    SteveC200 Used to drift, now I don't.
    Essex
    Why would you want to?
  11. adam-dorward
    adam-dorward Member
    Bournemouth
    So not smashing the limiter all the time and sound epic
  12. SteveC200
    Essex
    Have you considered lifting your foot a touch? And they dont sound e.p.i.c, they sound noisy and piss of track owners.
  13. lezbrucelee
    Kent
    Mines dead, Melted a piston yesterday & not sure why.
  14. Spanair
    Spanair Member
    Enfield, Middlesex
    Not at all just a couple of wires that you have to join with the ECU, say what 20 mins? Just have the pin diagram to hand. Was thinking of getting one for my current but no use really. Besides joining to the ECU wiring there's nothing else to do to install it just play with the settings for desired effects.
  15. schnabulator
    schnabulator Member
    Germany
    some people have installed a LED light between the power supply and the pump. the LED light turns on as soon as the pump gets power.
  16. lezbrucelee
    Kent
    Heres what my CA looked like on Saturday morning
    Heres what it looked like sunday morning
    This is no 4, no3 wasn't as bad & 1&2 where fine and showed no signs on det.
  17. cleanhandsjon
    cleanhandsjon Member
    worksop
    Sorry to see that fella, you've put a lot of work into it. Know what caused it yet?
  18. lezbrucelee
    Kent
    No not yet, hopefully ill get to the bottom of it next week.
  19. dori_wey
    dori_wey Member
    Bristol
    Any updates lez Bruce lee?
    Big changes comeing to my ca.
    Got a new Wardy manifold, suggest you all check his work out, around £450 gets you a very very tidy fully back purged, steam pipe manifold, no more crackS!
    I can get you his details or number if your interested it's easily full race quality.
    -getting a td05-18g
    -Tomei pon cams
    -sard 600cc injectors.
    Will be getting mapped by Greg @ pro tuner
  20. lezbrucelee
    Kent
    No not yet mate, ive not really looked too deep into it yet just shut up the workshop n left it sat there. A few people have suggested it could be different things. Not sure what im gonna do engine wise either stick at the ca's or go a different route.
