CA18DET preservation society
Thread in 'Drifting Chat / Pictures / Videos' started by dori_wey, Nov 11, 2012.
  1. 200sx_
    200sx_ PS13 x TD Power
    :thumbs:
  2. lezbrucelee
    lezbrucelee Southwall Smokers
    yer it is
  3. dori_wey
    dori_wey Member
    yea fair one but my ideas span as far as same set up ish less restrictive ie better piping, clean rocker covers out....... that's it.
    i wanna do something with this crankcase breather but to my understanding its impossible to with engine in ?
    that's what mine is like yet not as well set up nor do i have a filter
  4. 200sx_
    Can you not have another catch tank for the front left breather as well?
  5. lezbrucelee
    Yer i cleaned everything out when i built it, was amazed the amount of crap that was under the small plates in the cam covers, this is the thing which is the best setup??
  6. dori_wey
    dori_wey Member
    that's my set up there, well that's a mates mines not ass neat
  7. lezbrucelee
    Wheres the crank case breather go to in this setup?
    Not sure how you can get the crank case breather metal pipe out, maybe whip the starter motor out for better access you might be able to get to it then.
  8. dori_wey
    dori_wey Member
    i don't know if im having a moment here crank case breather standard is literally from head not rocker cover to bendy thing to block correct ? if that's the case mine is no change i think but this one im not sure, have you took the metal pipe out the equation ?
    yea i might look into that i can see it being a f***er of a task doing that though haha
  9. lezbrucelee
    Yer i took the metal pipe out, but only because i used an oversized hose that was bigger than the diameter of said metal pipe, no other reason.
    When i had the metal pipe off it had no junk in it unlike the cam covers and the top breather pipes, they were full of crap. So might not be worth the ball ache of taking it off, having said that every engine is different.
    Starter motor is easy to get out if you've got a decent wobble attachment in your tool set if not its a pig
  10. dori_wey
    dori_wey Member
    :worthy: That advice is what im looking for there, i am defiantly guna clean cam covers seams a very good plan and sort setup out with catch can and other than that im guna leave the metal pipe until ive had a chance to test it and see if i get the problem again, how a bloody catch can can have such an effect on a engine seams critical :wack: cheers for all the help here :thumbs: i wished you could get a possible engines guna knock or blow up gauge to not cause this kind of worry hahah :wack:
  11. dori_wey
    dori_wey Member
    also does any one know were you can get the turbo to down pipe bolts ? tried google but to know avail :smash:
  12. 200sx_
    As in bolts or the suds?
  13. dori_wey
    dori_wey Member
    both man the ones that screw into the turbo i think do you no were man ?
  14. pointz
    pointz Member
    Horsham Developments speak to Jez Tell him Pointz told you to call very very helpful guy! 01635 247477
  15. dori_wey
    dori_wey Member
    is there a link to any because come payday ill need to get them in a bit of a rush ?
  16. 200sx_
    I'm sure their the same as manifold to turbo studs?
  17. dori_wey
    dori_wey Member
    do you think so pal ?
  18. Mr III
    Mr III Active Member
    Anyone after some Tomie PonCams with Pulllies, as i have a spare set.
    Also have a nice CA18 for sale genuine 81k miles originally from an auto.
    Both in the for sale section.
    Cheers
    Tony
  19. steve109
    steve109 Member
    Day I bought mine
    During a freshen up
    After
    Need to get some better pictures and actually clean the whole thing, move battery to the boot, abs delete and rust prevention..
    Not bad for a 140k engine, runs like a trooper after sorting front crank seal, rear moons and a few water leaks
  20. dori_wey
    dori_wey Member
    looks good mate :) whats the specs mate ? plans ect?
