Ca18det tps wiring
Thread in 'Technical Questions' started by Adamround123, Mar 13, 2020.
  1. Adamround123
    Adamround123 Member
    Hi all, hoping someone can shed some light on this, managed to break a tps wire the other day, I believe it to be an earth, if the wire isn't touching where its broke, the car idles and revs normal, then if I touch the broken wires together the revs raise slightly then go back to normal, then same thing happens once they've been untouched. I assumed if a wire was broken, the tps wouldn't work properly. Will this affect anything?
    Cheers
    IMG_20200311_162351_zpsecvnkvny.
