Camber issues, after alignment too (E36)
Thread in 'Technical Questions' started by pitesy, Jun 6, 2011.
Tags:
  1. pitesy
    pitesy Member
    Hi there!
    So.. I bought an E36 325i about a year ago. I recently started to upgrade it (coilis, reversed evo mounts, eccentric wishbone bushes, etc.). When I bought the car, I was a complete newbie about cars (its my first car).
    On the right tower there were some cracks on the "inner lip" and some paint cracks too. I noticed, that it was mushroomed but it has been hammered straight since them.
    The problem is that after aligment my right tower has about 2.6 camber, and the left one has about 3.5 camber (both with reversed evo mounts).
    I don't want to sell the car, because they aren't that cheap here, as in the UK.
    My first guess was to give it in a body shop to inspect it, cut the damaged tower and weld an undamaged on one instead of this.
    What do you guys think?
    Any advice would be appreciated!
    Cheers
    pitesy
  2. MJG
    MJG Active Member
    The car may have had some damage, for 1deg of camber I really wouldn't bother cutting out the tower. Just get some adjustable top mounts and adjust one side different to the other. If it was me I just wouldn't bother, you'll never notice the difference anyway.
  3. pitesy
    pitesy Member
    The adjustable topmount idea sounds great! Thank you for your help! :thumbs:
  4. CIH
    CIH Member
    Did they measure SAI and Castor ? If so what are they ?
  5. pitesy
    pitesy Member
    I don't have the sheet, but iirc they didn't measure it. :(
    Could you tell me what could be seen on the SAI and castor differences?
  6. CIH
    CIH Member
    If the top mount is out of position then SAI and Castor would be similarily effected. If SAI and castor are (more or less) symmetrical I'd be thinking more like the strut or hub area.
  7. pitesy
    pitesy Member
    Thank you for your help! I will investigate some more then.
    I always learn something new here.. :wave:
