Can I make 420hp pump fuel 670hp e85 with this setup?
Thread in 'Technical Questions' started by Beveldrifts97, Dec 15, 2022.
  1. Beveldrifts97
    Beveldrifts97 New Member
    Engine S2 Rb25det block, neo head, Nitto head gasket, rb26 covers
    Rb26 rotating assembly
    86.5mm CP pistons
    N1 oil pump
    Nitto water pump
    Rb26 N1 crank w/ extended collar/long end
    rb26 maxspeedingrods
    Tomei 262 poncams, ARP head studs, rod bolts & main studs, R35 coilpacks
    G30-770, 45mm Turbosmart gate, tuned on 100plus/e85, 1000cc injectors
    DW400 fuel pump, heavy duty clutch
    Rb S2 big box
    R200 4.11, 3.4
    3L catch can, DabFab V band stainless steel exhaust manifold, 4" down pipe, 3" straight pipe redline intake manifold
    Link G4X Xtreme ecu
    Tuned on a hub dyno
  2. r3k1355
    r3k1355 Well-Known Member
    Is this a question or are you going to post a dyno graph?
    If you're putting it on a Dyno to tune, you'll get your answer, no need to ask the internet.
