**reduced** Super Cheap right then, my plan was to break the car and make every last penny i could from it but i just can't find the time to work on it. i've already sold the diff and the gearbox but that's it and the spec is the same as it was when i bought it from james. it now has a corbeua forza sport, 4 x 17x9's, 2 x 18x9's and, er, no dashboard. over the past few months the engine had developed the 'sr20 top end tapping noise' but the last couple of times i used it it hasn't made a sound, so an engine flush might just be needed to cure it once and for all. the car still looks the same as it does here and is NOT road legal at the mo, so even if it had a box and diff it would still need trailering away. the car won't take too much work to be M.O.T-able again or it could be left as a trailer only drift bitch. anyway, i need the space on my drive and more importantly, the money in my pocket and i'm basically after someone to make me an offer i can't refuse. to recap, i REALLY need the cash so i will take less than the going rate (whatever that is). make me an offer and you could have this car for less than you might think.... was 1500 now £1100 o.n.o! simply has to go!! i'm well aware that i could make a lot more than that by breaking it but i just haven't got the time or the proper resources and i need some money! **edit**just remembered, if you want to buy it with the intention of making it run again, it will need a fuel pump**edit**
alot. headlights fitting - only got one. inducators need fitting. rear number plate light needs wiring up. washer bottle needed. exhaust needs putting back on. has no light switches and i snipped the wires going to most of the controls inside. dashboard/clocks/gauges if these are required for mot. no horn. tyres all round. has no catalytic converter. hadnbake button needs attention that's all
so not much then haha..... still cheap car considering and some fo that stuff is easily obtainable threw breaks
jimbo, if you do break it dude, i need a few bit, plus may buy those new rims you got too. hope it doesnt come to that matey and goodluck with sale. be nice to see you compete nxt year
