Clearance
Thread in 'Driftworks Products & Enquiries' started by PhilMorrison, May 25, 2007.
  1. PhilMorrison
    PhilMorrison Driftworks Owner
    Staff Member
    When we moved office recently, it appeared we had a hugemongus pile of new stuff that's been sitting around for ages for whatever reason, so welcome to a bargain hunters dream. Descriptions are to the best of my knowledge, and item's are sold as seen.
    Energy Suspension S14 and S15 front lower arm bushes £25 (1 pair available)
    EnergyS14FrontLower.
    Energy Suspension S13/14/15 Tension rod bushes £25 a pair (2 pairs available)
    EnergyTensionBush.
    Energy Suspension S14 ARB mounts. May fit other cars. £30 for all four.
    ARBmount.
    Whiteline S13 Front lower arm bush. £40 per pair (2 pairs available)
    WhitelineS13FrontLowerBush.
    Whiteline S13/S14/S15 Tension Rod Bush. £35 per pair (4 pairs available)
    WhitelineTensionBush.
    SR20DET chromoly flywheel medium weight 9.8kg's 1 of £150
    SRflywheel1.
    SRflywheel2.
    Remote Tyre Pressure and temperature real time monitoring kit. As used in many racing series around the world. Very high quality peice of kit. we used one on our S14 last year. £95 a set (3 available)
    TyreGauge.
    #1 PhilMorrison, May 25, 2007
  2. PhilMorrison
    Staff Member
    5 stud Toyota 15-30mm adjustable wheel spacers. Brand new, but the kit is missing 2 x M12 x1.5 bolts which are very easy to find. £80
    ToyotaWheelSpacer.
    Nissan Sump plug adapter for either 1/8bsp or 1/8npt oil temp gauge. Loads available. please specify fitment. £6
    SumpPlug.
    Saga 60mm gauges, Defi rip offs basically, but are stand alone. I don't know alot about them, but I use a turbo one in my Aristo and it works fine. 1x Water Temp (lights up Amber) 1 x Turbo pressure (lights up Amber) 1 x Turbo pressure (lights up white) £65 each.
    SagaGauge.
    Driftworks Value Rear Camber Arms S14/S15/R33. These are the same arms that we currently sell, but they come with a 2 piece bearing instead of a 3 peice. They are still very high quality durable bearings. £90
    S14camberarm.
    Orange TRS 4point 2inch buckled harness. MOTable harness. £60
    Orange2pointharness.
    Orange TRS 6point 3 inch x 3inch x 2inch mustache style. £110
    Orange6pointharness.
    #2 PhilMorrison, May 25, 2007
  3. PhilMorrison
    Staff Member
    Nismo Thermostat £35
    NismoThermo.
    Mocal inline oil cooler thermostat 1/2bsp £35
    MocalThermo.
    SR20DET lightweight crank pulley 1x S14 and 1 x redtop S13 SR £40 each
    CrankPulley.
    BMW E32 and E34 subframe lock collar (rear beam locking collar) You need a pair per car, really easy to fit, and makes a massive difference to seemingly fine bushes according to James and Bon, who both have them fitted. £25 a pair.
    BMWsublock.
    350z Front Strut brace £70
    [imghttp://www.driftworks.com/images/Random/clearance/350zStrutbar.jpg[/img]
    GenuineApexi Filters. Not Z32 Fitment. Not a direct bolt on for anything that we know of. Has a multi hole pattern though, so should be able to be made to fit most cars with a little work, or an adapter plate making up. £40 each
    ApexiFilter1.
    ApexiFilter2.
    #3 PhilMorrison, May 25, 2007
  4. Mighty_Mini
    Mighty_Mini Go!Go!Auto
    Interested in the HKS Camp.. whats the delivery likely to be?
  5. astra_coupe
    astra_coupe having no luck
    is it just the screen or is everything in there for the HKS CAMP?
    cheeers sim
  6. DoriDave
    DoriDave ~~Sore-Arse~~
    Any of those tension rod bushes fit an R33???
  7. gtst lad
    gtst lad Ut oh
    I'll take this...
    Headertank/anti bubble thingymajig £25
    Let me know how to pay and will do asap :thumbs:
  8. LittleMark
    LittleMark -NIGHTSPIRIT-
    The HKS camp, Is basically the interface so you would need a Screen to use it!!
  9. Trotter
    Trotter Active Member
    this for me please!
    D2 S13 Camber Arms and Tension Rods £170 the set.
    the whole set thankyou please..
    how do you want me to pay? :)
  10. Sweeps
    Sweeps Active Member
  11. eight-six
    eight-six Active Member
    PM sent about the traction brackets!
  12. PhilMorrison
    Staff Member
    HKS camp is the unit only. It never comes with a screen, but you can get one of ebay I'm sure :)
    I think all of them do. Sorry should have listed them :)
  13. PhilMorrison
    Staff Member
    paypal@driftworks.com £8.50 delivery :)
  14. SteveC200
    SteveC200 Used to drift, now I don't.
    Got any 2871s down the back of the sofa you dont want?:D
  15. sammysideways
    sammysideways Active Member
    intrested in the t/b but unsure of how close it will fit.
    Agghh dunno
  16. gaz_moose
    gaz_moose .MTM.
    i will have one of the apexi filters i want the tapered one not the straight one.
  17. jap-si
    jap-si Active Member
    bollocks, wanted the traction brackets. :(
  18. tetsujin
    tetsujin Johnny 5 ALIVE
    I wanted the tracteion brackets weeks ago, had the cash and was told they where sold to Paz!!
  19. Drift A GTR
    Drift A GTR Member
    brought & payed for by ME yesterday :nod:
  20. Dan H
    Dan H Member
    I'll take a pair of these :thumbs:
    Just phoned the order through :thumbs:
    #20 Dan H, May 29, 2007
