For Sale Complete r154 5 speed conversion kit Supra/Soarer/jzx/gs
Thread in 'Parts for sale' started by Edviss, Jan 16, 2022.
Tags:
  1. Edviss
    Edviss Member
    Selling my spare R154 conversion kit – bought this for a future project as I was looking for soarer, ended up getting 300zx slicktop, so I have no need for this conversion kit now. Gearbox still has fluid inside and can be bench shifter in all gears for any testing purposes.
    · Mkiii Supra R154 box
    · r154 to 1JZ/2JZ Custom made bellhousing, not the nicest but does the job.
    · Mkiv supra rear gearbox mount aluminium
    · New (test fitted) Driftmotion R154/Mkiv rear Polyurethane gearbox mount kit with billet spacers and bolts https://www.driftmotion.com/R154-Swap-Mount-Kit-MK4-SC-GS-p/dm2643.htm
    · OEM used flywheel bolts
    · New grade 12.9 Flywheel bolts
    · Shifter extended to suit MKiv/soarer transmission tunnel – 4.75”
    · OEM shifter
    · CUBE billet short shifter
    · New electronic speed sensor
    · New pilot bearing
    · Clutch fork and Pin
    · Clutch slave cylinder
    · Complete Propshaft front and rear piece inc rear rubber coupling
    · Propshaft bolts
    · 1JZ/2JZ Clutch Release Bearing Carrier Sleeve
    · Braided Clutch line
    · Stage 1 organic clutch with pressure plate and flywheel (Street used at 400whp)
    · Pressure plate bolts
    Located in Rainham/Essex
    £2750
    upload_2022-1-16_15-21-53.
    upload_2022-1-16_15-22-9.
    upload_2022-1-16_15-22-23.
  2. Edviss
    Edviss Member
  3. Edviss
    Edviss Member
    Price Drop to 2600
  4. GeorgeHampl
    GeorgeHampl Member
    Any movement on the price?
  5. Edviss
    Edviss Member
    i had offer of £2400 which i have accepted, the guy is coming tomorrow. i can let you know later in the day if its still available.
  6. Edviss
    Edviss Member
    This is now sold
