Dan200s14 AAA s14a build
Thread in 'Project Cars and Builds Threads' started by dan200s14, May 16, 2012.
  1. dan200s14
    dan200s14 Member
    Oil cooler and filter relocation done but what a pain in the ass !
  2. dan200s14
    dan200s14 Member
    Whilst attempting to get the filter replacement boss to seal propperly I disturbed some wiring and now car is playing up, broken wire in ignitor wiring & broken terminal on lower plenum earth strap ( goes to nearly everything) note to self" don't be so heavy handed with old wiring"!
  3. dan200s14
    dan200s14 Member
    I did a spot of wire tidying and cut my iacv valve wiring out and proceeded to fully remove it from the car, because I am a ledgend!
    ( thank you Jonnymac,Dylan hart,Jason lowe & Nigel west for your technical help & wiring photos!
  4. dan200s14
    dan200s14 Member
    Well went to lydden on 27th 09 2014 and things were going really well but then the car is still getting too hot :-(
    So new project after speaking to stu Farley and a few mates is a redesign of the water cooling system needs to happen involving a bit of chopping on the front end but this is yet to be looked over properly!
    Anyway pic's from lydden
    Will foxwell in his 32
    Drift around my brother
    Smoke
    Using some lock!
  5. Jites
    Jites Active Member
    looking good man. I really want to try that track, looks a lot of fun!
  6. dan200s14
    dan200s14 Member
    It is great fun and a great place to learn!
  7. essexcapri25
    essexcapri25 Member
    Jites you have to bring the 14 and get mint to being the chaser to lydden. That would be epic
  8. dan200s14
    dan200s14 Member
    Hahaha long way for mediocre pmsl!
  9. dan200s14
    dan200s14 Member
    Next mission is work my way through the cooling system!
  10. Jites
    Jites Active Member
    sweet use of zip ties dude
  11. dan200s14
    dan200s14 Member
    Lol only a temp thing as needed to drive home, probably get some better fans before finilizing on fixings as I'm not overly impressed with these at the moment
  12. Pete_the_Russian
    Car sounds mental dude! Quick question, also looking for an oil cooler and filter relocation kit. The oem position sucks, I can see oil dripping all over the subframe when changing filters. What brand did you go for?
  13. dan200s14
    dan200s14 Member
    Thanks dude, Was just a cheap one like mishimoto
  14. Pete_the_Russian
    Is that for the actual oil cooler? I was more referring to the adapter. Did you remove the oem oil cooler btw?
  15. dan200s14
    dan200s14 Member
    Majesty relocation housings, and no but have been thinking about it
  16. dan200s14
    dan200s14 Member
    Rad moved forwards now, trying to decide whether to get viscous back on or whether to go twin evo fans .....hmmmmm
    #276 dan200s14, Oct 29, 2014
  17. dan200s14
    dan200s14 Member
    We'll recently I've been thinking up effective ways to sort cooling and I've managed to gay a viscous to fit
    Quite tight though
    I took it for a drive and the engine ran cooler than it has ever done, now to sort ducting to maximise efficiency
  18. Retro - Slide
    Retro - Slide Member
    What body kit is that? Like the colour :thumbs:
  19. dan200s14
    dan200s14 Member
    Thank you
    #279 dan200s14, Nov 9, 2014
  20. dan200s14
    dan200s14 Member
    it's a monkey magic uras kit
