Dan200s14 AAA s14a build
Thread in 'Project Cars and Builds Threads' started by dan200s14, May 16, 2012.
  1. dan200s14
    dan200s14 Member
    Shepton mallet / wincanton
    No but I was down Luke's the other day getting paint :-)
  2. dan200s14
    dan200s14 Member
    Finally managed to get fmic piping to line up with the exhaust and inlet :-)
    Just waiting to get fuel pipe to rerun it across the passenger side
    Just need to find some where to move these V
  3. s14a L.K
    s14a L.K Member
    great looking car, love it in white! has given me some good ideas for mine :D
  4. dan200s14
    dan200s14 Member
    Will be some more changes once the engine is up and running :-)
  5. dave_noble
    dave_noble Member
    looks good, nice in white
  6. dan200s14
    dan200s14 Member
    Not too much happening ATM just waiting on my linkage to return now and to find a rad with the inlet at top centerish so I don't have to mess about with stuff and then it's just getting down to wiring. Hoping the linkage will return soon so the box can go back together so I can then get to try the new prop in there and have it all in 1 lump again :-)
  7. dan200s14
    dan200s14 Member
    Ive been toying with thr idea of moving the engine bay fuse box to a dash location to hide it out the way :-)
    #27 dan200s14, Jun 19, 2012
  8. dan200s14
    dan200s14 Member
    Right progress since last post. I have Ripped all the fuel lines out and am getting ready to lay the new 10mm copper pipes in! Only thing I can't decide on is whether I go inside or underneath both have positive points but am thinking underneath is easier and probably safer just not so easy working on ur back under a car.
    Other bits I've been working my way through
    moving the fuse box involved cutting 30ish wires do I numbered the wires on each side of the cut point to make it easy to rejoin. Then completely remove the fuse box but not all wires from the same point as there are 3 wires that each have additional wires coming from them so easier to just remove the wires further back to avoid more soldering :)
    Then you will need to sort the wires out that need to go back into the cabin and take the wires out of the grommet. I reinsulated these wires at this point as is much easier to do before it's back in dash but left around 6" to allow me space to work :), now I soldered the 10ish that are left at the front to extension wires and insulated all of them together and sent them into the cabin following the route of the last bunch, now I joined the wires in the car to the fuse box! Now there are 3 wires remaining at the fuse box to be extended to the front. So solder them in insulate the wires together and send them back to the engine bay and join them back to the loom then re wrap it and job done :D other than the supply (battery)wires on the fuse box which I would gues doesn't need explaining
  9. dan200s14
    dan200s14 Member
    On the rad topic I have a solution I have not seen or heard of anyone else using it yet but fits perfect size wise but location lugs at bottom don't match other than that it is much nicer to work with than the sr20det and ca18det rads!
    Just need some fans that will fit in front of the rad
    Some pics V :-)
    The rad is from a Honda accord
    #29 dan200s14, Jun 23, 2012
  10. dan200s14
    dan200s14 Member
    I just wanna drive the f...ing thing lol
    #30 dan200s14, Jun 23, 2012
  11. dan200s14
    dan200s14 Member
    Bit of a lack of progress since Saturday as I managed to bust the imoboliser in my daily!!! ******* joy
  12. bigboi
    bigboi Member
    Nice car! Why the 1JZ though, just out of interest :)
  13. dan200s14
    dan200s14 Member
    Cos I like it :-)
    #33 dan200s14, Jun 26, 2012
  14. dan200s14
    dan200s14 Member
    Fusebox loom rewrapped :-)
    Fuse box is all reinsulated just needs flipping over to allow access to the relays from below :-)
  15. dan200s14
    dan200s14 Member
    Hopefully this will now fit!
  16. Jites
    Jites Active Member
    Aberdeen
    I know your still working on the car but are you leaving the loom under the arch in the above pic?
  17. dan200s14
    dan200s14 Member
    At the moment yes but will probably end up moving it to the top of the chassis rail before I have finnished with the looms as things under bonnet still need moving about a little.
  18. counteract
    counteract -o=me
    Was good to meet you last night man, thanks for the ARB :)
    Looking forward to seeing more on this! Never really thought about how much of a ballache it is doing the swap until we were talking last night!
  19. DV19
    DV19 Member
    nice work so far..
  20. dan200s14
    dan200s14 Member
    Been doing some more just ain't had much time to post it and lift the pics yet. Maybe later :-)
