Dan200s14 AAA s14a build
Thread in 'Project Cars and Builds Threads' started by dan200s14, May 16, 2012.
  1. diamondsink
    diamondsink Kyouto Drift
    Kyouto HQ, Bristol
    Christ! sort that sig out!
  2. dan200s14
    dan200s14 Member
    Shepton mallet / wincanton
  3. dan200s14
    dan200s14 Member
    I'm off to collect my extended gearlinkage tonight so might fit the gearbox and prop back to the car if I get time :-)
  4. dan200s14
    dan200s14 Member
    Linkage needs some adjustment so back to a mate it goes! :-(
    On a plus note, r33 handbrake cables mounted and fuel pipes are on the correct side now :-)
  5. dan200s14
    dan200s14 Member
    Today I finnished the fuel piping and fastened it all up [​IMG]
  6. dan200s14
    dan200s14 Member
    Fitted and tightened the flywheel :-) [​IMG]
  7. dan200s14
    dan200s14 Member
    Tryed to assemble the clutch pull bearing but the spring clip that holds the hub to the bearing doesn't seem to fit and I'm not quite know why considering that they are all new parts from Toyota with all the part numbers listed. Confussed!!!!!
  8. dan200s14
    dan200s14 Member
    90560-50001
    96152-00500
    90560-79001
    31264-14060
    90520-75001
    90206-12006
    All seem too big for my r154 clutch pull bearing and hub
    Thanks Declan for listening to me whine about this issue!
    And thanks for finding the right part numbers
    90201-45023small washer plate
    90201-71001 big washer plate
    90206-72001 wave spring clip
    90520-67001 big spring clip
    96152-00450 small c clip
    31264-14040 coned washer
    #48 dan200s14, Jul 25, 2012
  9. dan200s14
    dan200s14 Member
  10. dan200s14
    dan200s14 Member
    Todo list hasn't really changed in weeks as still waiting on a few bits to be finnished by a friend before the wiring can be started :-(
  11. dan200s14
    dan200s14 Member
    Gearbox is in and gearstick is fitted just need the prop back and to sort the heater matrix hose's and clutch master cylinder clearence issue and then it is ready for electrics :-D
  12. dan200s14
    dan200s14 Member
  13. eoghan.c
    eoghan.c Member
    sweet son good work going on here =)
  14. dan200s14
    dan200s14 Member
    Rad is all mounted and plumbed in :)
    #55 dan200s14, Aug 28, 2012
  15. xollis69x
    xollis69x New Member
    Wells
    Can not wait to hear the girl running :)
  16. dan200s14
    dan200s14 Member
  17. dan200s14
    dan200s14 Member
  18. counteract
    counteract -o=me
    Getting closer! :D
  19. dan200s14
    dan200s14 Member
    Yea getting to the point it will just be wiring :-)
