and then skid vruuuum vruuuum skid etc etc it will be interesting to see how she's sitting when sideways
Especially as I have no Arb ATM. If I can go to Dakota drift and drag on 17th we will c lol! Probably hideousness
Smoke cleared a bit after this and found some boost leaks was running much happier after she had a little thrash :-)
Cars in bits again to fit Kenlow fan switch Rb ally rad 106 gti twin fans I know the 106 fans are a bit tramp but with a little trimming they fit better than anything I've found and loads of air movement :-D
Pics of the 106 fan setup when done would be good, interested to see how well they fit as I want to do away with my viscous.
I will get photos tomorrow dude, if u cut the luggs off the bottom of thefan housing and then cut the bolting points about 2 mm above the holes it slots in perfect under the front cross bar then from there you can mark the housing that you can trim back to sit right underneath, put rad back in job done :-). Fits like a glove!
Possibly but I wanna have a look at the diff as it did seem to make more noise than usual so will see what happens :-)!!!
