Dan200s14 AAA s14a build
Thread in 'Project Cars and Builds Threads' started by dan200s14, May 16, 2012.
  1. dan200s14
    dan200s14 Member
    Shepton mallet / wincanton
  2. dan200s14
    dan200s14 Member
    Next project is to raise the engine an inch as engine sits too low so the sump is below the subframe by a inch and sort the handling and arms out.
    Here are a bunch of pics from the sw-PC sprint on Saturday
    #102 dan200s14, Mar 10, 2013
  3. Clive
    Clive Active Member
    chichester, west sussex nr portsmouth
    WTF Dan, your sump is LOWER then your ultra low kit!! :wack:
  4. dan200s14
    dan200s14 Member
    Exactly what I've been saying. It's 1" below subframe as I said lol
  5. dan200s14
    dan200s14 Member
  6. dan200s14
    dan200s14 Member
    I ventured out to Dakota drift & drag (smeatharp) and had a good day but noticed things need more tweaking to suit me more. Here are some more pictures.
    Oops!!!
  7. dan200s14
    dan200s14 Member
    Things to do now:
    Chop down gearstick :-) ( to sensible hight)
    Search around for weeping brake pipe (as loosing minute amounts of fluid)
    Increase the preload on my front suspension and a little tweak on the rear)
    So not too bad really but want too get it done so that its ready for it next play day on the 6th!
    I need to find an effective way of increasing my steering lock until I choose to mod or change hubs
  8. cliodan26
    cliodan26 Member
    Trowbridge Wiltshire
    If your not going with geomasters / modded hub's , id go for tein inner tie rod's and lock spacers then grind down your lock stops also if youve got adjustable tension rod's adjust them for slightly more castor
    car sounded awesome at the weekend you just need to sort that ride height out when you raise the engine haha
    #108 cliodan26, Mar 26, 2013
  9. dan200s14
    dan200s14 Member
    Thanks bud.
    I'm still unsure if there is a clutch master up to the job that is small enough to fit :-(. I gotta keep looking lol
    Car was very pokey and didn't handle too bad but was very wallowy!
  10. tomski200
    tomski200 Member
    Southend
    Very cool. I'm loving the tyre/roof rack
  11. dan200s14
    dan200s14 Member
  12. dan200s14
    dan200s14 Member
    After a little drift day at zoyland I am thinking that I will need some 15kg front hsd springs as it still a little wallow on transition with preload set fairly high but here is a few photos :-)
  13. dan200s14
    dan200s14 Member
    Modded up stock steering a little for meantime
    From [​IMG]
    To [​IMG]
    #113 dan200s14, Apr 29, 2013
  14. status unknown
    What have you done to the steering? Just the lock spacers?
  15. dan200s14
    dan200s14 Member
    Lock spacers and bump stops
  16. status unknown
    My spacers fitted on alright then?
  17. dan200s14
    dan200s14 Member
    Yea not to bad I guess haven't driven far on them yet though as I had tracking Saturday. Won't really get to test it till pod probably
  18. dan200s14
    dan200s14 Member
    I've now put a new welded diff in with the new solid mounts. Changed gearbox oil to 75-90 as 80-90 is 2 thick as far as I can tell..
  19. dan200s14
    dan200s14 Member
    De-scar nearly done
    Respray bonnet
  20. dan200s14
    dan200s14 Member
