For Sale Defi 60mm gauges and 80mm tach
Thread in 'Parts for sale' started by pinka, Aug 25, 2018.
  1. pinka
    pinka Member
    Riga, Latvia
    Sorry was super busy last weeks, today will get back at you!
  2. stinky 32
    stinky 32 Member
    fife
    Any luck on this bud?
  3. pinka
    pinka Member
    Riga, Latvia
    Hi, just checked all the stuff, and it looks like the tacho will not work without the controller. There are 4 wire plug going from the link to gauge and a two wire plug going to the link with a single signal wire.
    #23 pinka, Oct 23, 2018
  4. pinka
    pinka Member
    Riga, Latvia
    Everything still up for grabs!
  5. pinka
    pinka Member
    Riga, Latvia
    Updated the first post!
    The oil pressure sensor set will not work with this defi link, only maybe if you change the connector.
    The sensor wire for the tach can be purchased separately from JDM distro or other shops.
  6. pinka
    pinka Member
    Riga, Latvia
    Lets get festive! All gauges 450 gbp delivered!
  7. pinka
    pinka Member
    Riga, Latvia
    Oil pressure gauge gone, all other avaliable!
  8. _Tume
    _Tume New Member
  9. pinka
    pinka Member
    Riga, Latvia
    Oil temperature gauge with sensor and wires 150 EUR (130 GBP)
    1543313804_4067.
    Water temperature gauge with sensor and wires 150 EUR (130 GBP)
    1543313803_3639.
    Boost pressure gauge with sensor and wires 150 EUR (130 GBP)
    1543313801_1667.
    Tachometer 80mm without sensor wire 50 EUR (45 GBP)
    1543313805_6050.
    Control unit 50 EUR (45 GBP) I can not find the power wire for the link.
    1543313804_5395.
    Can ship worldwide at buyers expenses
    If buy whole set: 450 EUR (400 GBP) + shiping
    Also have a brand new radium top feed fuel rail for 1JZ non vvti with brackets for 48mm injectors. (rail and brackets only)
    http://www.radiumauto.com/Fuel-Rail-Top-Feed-Conversion-Toyota-1JZ-GTE-Non-VVT-i-P945.aspx
  10. pinka
    pinka Member
    Riga, Latvia
    Bump, the spring is coming!
  11. tom72
    tom72 Member
    Bristol
    Will take boost if you split
  12. pinka
    pinka Member
    Riga, Latvia
    Sure I can split!
  13. pinka
    pinka Member
    Riga, Latvia
    Boost gauge, water temp gauge, oil temp gauge,tach and link controller sold!
    Also has a brand new Oil pressure sensor set PDF08106SS 150 EUR (130 GBP)
    1543313806_7575.
    1543313807_8739.
    #33 pinka, Apr 5, 2019
  14. vctrburk
    vctrburk New Member
    Hi there, you hardly have the oil pressure gauge?
  15. pinka
    pinka Member
    Riga, Latvia
    Hi, sorry all gauges gone, only new oil sender set for sale.
