Devolutions Strawberry faced 180sx
Thread in 'Project Cars and Builds Threads' started by devolve.co.nz, Jul 31, 2010.
  1. YashioFactory
    YashioFactory Active Member
    Rhondda, South Wales
  2. lee+jo
    lee+jo Member
    coventry
    awsome car mate like the blue will look great when its all painted.
  3. devolve.co.nz
    devolve.co.nz Member
    Auckland, New Zealand
    Decided that the old bumper just wasn't doing the car any favours so purchased a final konnexion front bumper for it instead
    also replaced the cracked plastic overflow with a stylish alunimium one from circuit sports
    the moved the powersteering res to the radiator support as it was getting cooked by the high mounted turbo
    with new braided lines
  4. Max-san
    Max-san Member
    Brands Hatch
    Nice conversion!
    BUT, one thing I noticed, the way you mounted the oilcooler is wrong. You can either turn it 90 deg with the return pipe at the bottom or 180deg.
    If you leave it like this it will collect air starting from the top rows, in the mean time only the 3-4 bottom rows get a decent flow with cooling effect.
    So that´s gonna ruin the point of having a oilcooler :)
  5. m.d.
    m.d. Active Member
    really like that front end with the new front bumper, and thats exactly what ive wanted to do with my pas resovoir for ages, off i go to do mine tomorrow lol
  6. devolve.co.nz
    Never thought of that, if it becomes a problem I'll change it .
    Just need my front guards done in steel then its off for paint followed by a tune and low volume cert. Been along time in the build but the end is in sight now
  7. devolve.co.nz
    Rolled the rear guards and dialed some camber out of it, still needs a proper alignment as it was just done in the shed with a piece of string a ruler and a large square.
    Took it out of the shed to check the speedo was working so decided to fire off a couple of quick shots.
    speedo now works properly so thats another thing crossed off the list
    Still need to change the wing mirrors over to a matched set that work properly, have my steel front guards made, get DKM to do some sweet twin tips on the rear, get it tuned and certed, then all finished off in a few coats of ford sonic blue. And get the dash flocked and tidy
  8. Ed
    Ed Anti-Dibs
    Surrey
    Nice, liking that. So glad you ditched that other bumper, your new one is much better.
  9. ryn004
    ryn004 Member
    Clean look! NEver seen the 180sx/s15 combo before. CAn't wait to see it all in one color.
  10. Dandy
    Dandy Member
    Paris, FRANCE
    Love your car dude! Wanna see the final result when it will be painted :)
  11. gibbo s14
    gibbo s14 the yarco
    great yarmouth
    looks cool . need to get it painted
  12. davey
    davey Active Member
    a workshop in bristol
    looks good dude, your doing well :)
  13. devolve.co.nz
    In the process of pricing up paint at the moment. Trust me to choose a colour with numerous pearls and metallics, going to have to call in some favours to get a better price.
  14. devolve.co.nz
    Finally found someone to fabricate up my steel guards so I dont have to use the ill fitting shitty fibreglass ones.
    First step was to cut out the s13 indicator mounts and replace them with the s15 indicator mounts
    The next step was to trim the s15 guard
    Mount the s13 part and check pannel gaps
    the s15 guard was then mounted and overlayed over the s13 guard, and the s13 guard marked for trimming
    they were then welded up with a slight overlap to mininise distortion
    Quite happy with how they came out, not bad for about 3/4s of a days work
  15. Jimfunn
    Jimfunn New Member
    SW
    Thats a pretty sweet job man! Good work
  16. projects
    projects Member
    Cambridge, NZ
    well done there man! i thought about doing a similar guard mod with the S13-14a guards.
    You made it look pretty simple, maybe if i destroy my kit i'll give it a go.
  17. devolve.co.nz
    new heat shield made up to stop melting wiring looms
  18. devolve.co.nz
    getting everything ready for its tune at the end of the week
    picked up a Z32 AFM with a broken mount
    made up an ali adaptor plate
    a bit of silicone and knead it later its all fixed and good to go
    [​IMG]Brought a new plug from petroject and wired it in so I now have dual AFM plugs so I can drive with the sr20det AFM then switch over to the Z32 AFM for the tune. Will just need to steal the filter off of the R33 for the day
    and a sneak peak at the new exhaust system thanks to Keg @ DKM fabrication
  19. devolve.co.nz
    dyno tuned 202kw at the wheels before the clutch started to slip
  20. devolve.co.nz
    decided to lower it abit more
