Does my bb turbo have an oil restrictor? See pic.
Thread in 'Technical Questions' started by marki, Jun 19, 2015.
  1. marki
    marki New Member
    Does my turbo have an oil restrictor in it?? (see pic) or will i need to buy one?
    Thanks.
  2. Ruishy1
    Ruishy1 Active Member
    pic doesn't work
  3. Stavros
    Stavros Active Member
    It's a GT2560R, and should be able to just bolt it on and run it with the stock restrictor inside the oil feed. My mates one doesn't smoke one bit like that.
    #3 Stavros, Jun 19, 2015
  4. Bozu
    Bozu Member
    Yeah your turbo does not have a restrictor so you need to fit one.
    Always wondered if fitting the restrictor at the turbo side rather than the engine side would be better as i would imagine the feed line is filled quicker with oil
  5. Swampy442
    Swampy442 Active Member
    At the turbo side? In the drain not the feed line?
