Drifting on alloys
Thread in 'Drifting Chat / Pictures / Videos' started by Jaiimez, Jun 27, 2021.
  1. Jaiimez
    Jaiimez New Member
    Norfolk, UK
    so I brought an RX8 to use for drifting and I had planned to buy some steel rims to use for drifting to avoid damaging the alloys when a tyre blows, but now I'm reading and it seems steels are bad for drifting, so my question, am I gonna take damage on my rims if I blow a tyre or am I worrying about nothing?
    • Funny Funny x 1
  2. initial_j
    initial_j Made guy
    Ashford, Kent
    100% worrying about nothing
    You don’t drift until tyres explode. They will become useless and undriveable on way before they are anywhere near popping
  3. crazyae86
    crazyae86 Well-Known Member
    greece-uk
    1526736_10203558344014097_1317048264487989032_n.
  4. Jaiimez
    Jaiimez New Member
    Norfolk, UK
    fair enough, I'd been to a few spectator events and seen people pop tyres locally I was concerned that would be a normal thing.
  5. initial_j
    initial_j Made guy
    Ashford, Kent
    What do you mean by spectator events?
    I can’t recall anyone I know popping a tyre drifting.
    I’ve seen boy racers pop tyres doing ten minute long burnouts/donuts.
    But that isn’t drifting
  6. Jaiimez
    Jaiimez New Member
    Norfolk, UK
    A group at our local speedway runs regular drift days, I've been to watch a few times before covid stopped allowing spectators.
    Maybe I'm wrong and have misunderstood what I've heard, but seems like you'd hear a loud bang, then one of the cars would head back to the pit, I've assumed it's a tyre blowing.
  7. initial_j
    initial_j Made guy
    Ashford, Kent
    I wouldn’t worry about it
    I mean yeah you can blow a tyre out if you really try. I.e doing a burnout for ten minutes but that really isn’t drifting that’s just dicking around
    Normal drifting once you run out of tread you are going to know about it long before it’s anywhere near going pop, you’ll have absolutely no grip what so ever. Thats when you go and put another set on.
    So in short, nothing to worry about
    Wont pop tyres unless you really go out of your way to
  8. Jaiimez
    Jaiimez New Member
    Norfolk, UK
    Fair enough hopefully it'll be apparent to me as much as you said.
    Further to that, in average how often do you find yourself changing tyres, are one set lasting multiple days, or do you use multiple sets a day?
    I've got 4 part worns aside for my first session, are they likely to last the day, or do I want to consider getting some more, they've how reasonable tread on they're about half way through their standard road life.
  9. initial_j
    initial_j Made guy
    Ashford, Kent
    Depends on the weather
    if it’s a wet day, one set will last all day.
    In the dry, depends on power level of your car, the surface of the track, what psi you’re running, how long the track is
    Take as many as you have space for.
    Personally I run brand new budgets, all the same brand so there is consistency. More expensive than part worns but you don’t have to pay to change the tyres over twice.
    Depends a lot on seat time, if you’re having to queue up for 45 mins of every hour then you won’t get through as many vs an open fast track all day
    Take as many as you can for the first day and see how it goes.
  10. Jaiimez
    Jaiimez New Member
    Norfolk, UK
    I'm not running much power, it's a 4-port RX8 (192hp), it'll be at Norfolk Arena if your aware of it, I did plan to do similar with new tyres, I just obtained 4 part worns from a friend for free, but once those are done, I'll probably go onto using new budget tyres.
    as far as PSI ext that's all stuff I guess I need to learn. I've got 0 real world experience.
  11. initial_j
    initial_j Made guy
    Ashford, Kent
    You should be fine
    Start at 40psi in the rears, 30 in the front.
    Get out there and enjoy yourself
  12. Josh25252
    Josh25252 New Member
    manchester
    did you compression check yours wondering whats the compression ? or you just bought a beater that ull run till engine blows ?
  13. Jaiimez
    Jaiimez New Member
    Norfolk, UK
    I brought it blind, but was only rebuilt 18k ago, so should be pretty good, I also am keen to learn to rebuild it eventually, so my attitude was it'll blow up eventually and it's a learning experience when they happens.
  14. Jaiimez
    Jaiimez New Member
    Norfolk, UK
    I'm assuming my fronts should last all day?
