Driftworks CS2 updated! Latest revisions inside...
Thread in 'Driftworks Products & Enquiries' started by kam, Sep 27, 2012.
  1. kam
    kam I've touched Chris Parry
    Driftworks CS2 in the webshop!
    We've made some changes to the already incredible CS2 suspension system for S13/14/15. You now have:
    Camber AND Castor adjustable top mounts, allowing you to dial in desired castor at the top of the strut, whilst
    keeping the wheel centered in the arch and reducing LCA bind.
    Upper castor adjustment can also help you acheive more steering lock when using Driftworks Geomaster components as you can use the adjustable tension rod to change relationship between lower arm and tie rod over centre angle, then refine your castor setting at the top mount.
    Super low friction roller bearing front spring seats, for improved steering feel/control on lock and during transitions.
    And they're still the same price! Doesn't get much better than that :)
    To save potential questions:
    1) The extra's are not currently available for existing CS2 owners, but will be soon with proof of initial purchase.
    2) The group buy CS2's will ALL have these latest revisions.
    If you have any other questions fire away! :)
    #1 kam, Sep 27, 2012
  2. Bolf
    Bolf Resident Nut Job.
    edit , ignore me ,i cannot read , :D
    #2 Bolf, Sep 27, 2012
  3. pipcarder
    pipcarder Member
    Will these be avalible for models other than s-bodys?
  4. kam
    No :)
  5. smokebillowing
    smokebillowing Active Member
    Sorry to drag up an ancient thread, but can I now upgrade my non-caster adjustable top mounts?
    Thanks.
    #5 smokebillowing, May 11, 2014
  6. BHPSeeker
    BHPSeeker Member
    Are these suitable for road use as well as track, I am building my S14a which will be mainly used for Road/Daily so don't want anything too harsh!
  7. smokebillowing
    Yes, they're fine for road, you can set them up as harsh or soft as you like.
  8. ZacKisBacK
    ZacKisBacK Member
    I didn't get this with my CS2 coilovers: Super low friction roller bearing front spring seats, for improved steering feel/control on lock and during transitions
    Instead, I did get a plastic ring that isn't the correct Ø and is not properly seating the spring. I'm looking for some roller bearings (torrington) to replace those plastic things.... Any supplier?
  9. kam
    Sorry, missed this. Email us please sales@driftworks.com with your order details (name, address) :)
  10. kam
    Email us, sales@driftworks.com
    Thanks
  11. kam
    Depends what you define as "harsh". They're firmer than a stock S14, but perfectly capable on the road, which loads of people use them for.
    The R32 is a full blown race car on CS2, rides really well on the street.
  12. ZacKisBacK
    ZacKisBacK Member
    Done, thanks!
    In fact, I was wrong and mixed the top spring seat and the bottom spring seat, so my coilovers were complete and without anything missing. Thank you Kam for your fast reply! ;)
    #12 ZacKisBacK, May 19, 2014
  13. kam
    You're welcome, cheers :)
  14. stefan
    stefan Member
    is this upgrade available now? i enquired about this months ago and was told the top mounts and spring seats couldn't be supplied separately due to stock issues.
  15. kam
    Email us please sales@driftworks.com with your order details (name, address).
  16. BHPSeeker
    BHPSeeker Member
    I like firm, firm is good, I just don't want to be skaen to death on the way to work every day :euge:
  17. AndyS13
    AndyS13 Member
    Put it this way I had apex gen 2 limos which were custom ordered through apex to cope with bupy roads 3/4 spring rate and I decided to try a set of cs2s and was shocked to find that even with a much higher spring rate they actually absorbed the bumps better and had better ride quality and handling. Better than any coilover I have used so far and ive used a lot.
