Driftworks GeoMaster Hub Knuckles
Thread in 'Driftworks Products & Enquiries' started by PhilMorrison, Dec 17, 2009.
  1. Paz
    Paz -NIGHTSPIRIT FAMILY- UK Drift Since 2001
    That PS is so legit. That last picture is sweet.
  2. Karan
    Karan Active Member
    Here's a little clip of my trying my geos out for the first time.
  3. Hudson.
    Hudson. JIBES
    Thanks :D! This ones cool!
    Karan I love your car! Definately the coolest car on the day :)
  4. kam
    kam I've touched Chris Parry
    Car looks sweet Hudson.
    What alignment you using?
  5. Hudson.
    Hudson. JIBES
    Kinda based it on some of Mitto's settings but:
    Front-
    -4*30' Camber
    7* Caster
    0 Toe (it felt shit to drive on the street with toe out so I got it changed to parallel, better but I think its the camber that makes it twitchy more than anything!!)
    Advan AD08's
    Rear-
    -1*10' Camber
    0 Toe (Had toe in at awesomefest last year and struggled with it to break free just not enough power)
    Though at Lydden on Saturday I bent a tie rod in the first session so I guess all the alignent was irrelevant haha. Put 50psi in the rears to get going right, too grippy for the power otherwise! :D
  6. Karan
    Karan Active Member
    Was gutted when I saw the damage on your ps dude! Where did u manage to do that?
  7. Black nissan
    Black nissan Guest
    Has anybody drawing with sizes of this spacer?
  8. kam
    Nice neutral setup then Hudson, just the grip coming from the Geomasters :)
  9. kam
    Do you need a spacer? If you've purchsed Geomasters from us just email your order details across and I'll get them out FOC today. sales@driftworks.com
  10. -sideslide-
    -sideslide- "ent it"
    Do these geo 2 rears not work with teins I can't seem to stop the tension arm bolt hitting the bottom of the coilover?
  11. Clive
    Clive Active Member
    Put tension arm on first with head of bolt coilover side.
    Coilovers are inner and outer too
  12. -sideslide-
    Yeah thats how I had them
    even tried the coil overs both way around bolt still hits.
    Do you have a photo clive?
    So it took me an hour to put the engine+box in and make the mounts, 15 mins to fit the front suspension, an hour to fit the doors,bumpers,wings and quarters and 6 hours to not have the geometer fitted?
    At that rate it would have been cheaper, quicker and would know to rolling to have made a complete subframe and modified the chassis rails that keep the diff in line too.
    So any body wants 2 rear geomaster 2s never been used to attempted to fit them I have 2 for sale.
    £300 delivered brand new but have had the R33 fitted to them and just have a few chips in the paint work.
    #252 -sideslide-, Jul 12, 2014
  13. Slamz
    Slamz Member
    Did you get this sorted? I have the same issue with mine :(
  14. frozenwaffles
    frozenwaffles New Member
    Hi peeps, so just about to fit these to my R33 gtst. very excited...
    Couple of hurdles so far however...
    I need to source S15 Hub/Spindle Nuts (these should be supplied with the kit).
    I bought some shorter high tensile bolts that bolt the rear hub to the knuckle. The factory R33 ones have too much shoulder and are way too long with the new Geomaster Knuckle (these should be supplied with the kit too).
    I needed to buy S15 hubs, but i did know this so that was good. However the ones i was supplied don't have studs so i need to get them too.
    Will be fitting as much up as i can tomorrow. Will be interesting to see how we go :)
  15. Marphie21
    Marphie21 New Member
    Is there still an issue using an r32/33 rear drum-in-disc set up? (i.e. Hand brake does not lock as well?)
    Also, does driftworks now include the right spec bolts and washers for installation?
  16. HCR_guy
    HCR_guy New Member
    Just wondering if you all still make the R32 ones? I will be ordering loads from you all soon. Thanks.
  17. Starkey
    Starkey Administrator
    Staff Member
