Driftworks GeoMaster Hub Knuckles
Thread in 'Driftworks Products & Enquiries' started by PhilMorrison, Dec 17, 2009.
  1. royal
    royal S1- F.T break!
    The MA motorsports knuckles are just normal knuckles with the the steering arm part cut shorter. This will give you extra lock and faster steering but you'll still have the poor alignement of a standard lowered car. Roll center will be bad because the lower arm is already angled too far up before the suspension even starts compressing. You also get bad bump steer and other issues that make for poor handling.
    The Driftworks ones give you a new hub that is designed so the suspension arms and steering arm pickup are in the perfect place for a lowered car to eliminate all these problems.
  2. matt
    matt -NIGHTSPIRIT FAMILY-
    The PSM kit is similar to the MAM kit, they basically just sell a 'U' shaped piece of metal with a dowel in that goes into the original hole in the knuckle. The steering arm bolts to the bottom of that piece, closer to the hub to give you more angle. Its a nice cheap kit but the geometry correction you get with the Geomaster knuckles makes the PSM kit look a bit of a bodge:(
  3. mitto
    mitto -NIGHTSPIRT FAMILY-
    Got a set of knuckles yesterday from the orange gang... if you have pre-ordered ordered you will knot be dissapointed!!! :worthy:
  4. Franky
    Franky New Member
    Are the Offset Rack Spacers now available?
  5. Nick Sheen
    Nick Sheen Box Assassin
    Yes they are finished now also, when ordering the Hub Knuckles. Just select the offset rack spacers in the drop down menu. £85.00 extra.
  6. steady eddie
    steady eddie Member
    A couple of quick questions:
    1. Whats the length of the thread that does into the rack?
    2. Is there an option to purchase without buying the knuckles?
    Cheers for any info :)
  7. PhilMorrison
    PhilMorrison Driftworks Owner
    Staff Member
    1: a lot. circa 25mm IIRC
    2: There will be :nod:. They will be £105. You can ring up and order a set or wait until we have time to wack them in the shop :thumbs:
  8. mitto
    for the sake of it, you'd be daft not to get the knuckles and offset spacers together. Whilst uras discontinued thier spacers, i believe the solution that DW have come up with is far superior and will not suffer from the same issues as the uras items. ie... falling off! lol.
    As i said to the boys at HQ, it will not suprise me to see these knuckles and spacers go global.
  9. Ninjabread
    Ninjabread Member
    I've been spreading the word :)
  10. angrydan
    angrydan raaage
    should have mine this week, be rude not to like!!
  11. matt
    ooooooooh, I'll be ringing in the morning:D
  12. Polo
    Polo Sr20 parts man!
    For sure!! Very good product and stupid cheap price!!
    Im still really tempted by the full set:nod:
  13. mitto
    do it. they are worth every penny for the roll centre correction alone!
  14. matt
    Soooo... which side does the longer spacer go on?
  15. MR-steveo
    MR-steveo TNS MAN CHILD
    there sided... cant get it wrong
  16. matt
    sweet, I've not even taken them out of the bag yet so hadn't really looked:)
  17. kam
    kam I've touched Chris Parry
    Being raved about on Zilvia too....
    Click
  18. irishmex2
    irishmex2 Member
    Got my set during the week they are awsome quality cant wait to fit
    them tomorrow:thumbs:
  19. ChristianBS
    ChristianBS Member
    Now i have got my nuckles, and they look very good. Start fitted them these weekend. but I run into a problem, I got 2 right sided front nuckles:confused: (I email you DW guys about it)
    The offset rackspacers, I see you write here that you cannot mount them wrong, but for me these doesn't really look correct. Please see pics..
    For the rear nuckles, I had to bore up and cut some of metal to fit the brake caliper. I use D2 big brake kit. But they fitted with no mods on oem nuckles. Just a notice for others that these could be an issue.
    Random bad cell phone pics...
  20. royal
    Do those bump stops on the blue front lower arms get in the way of uber lock or are they ok?
    I expect you know but the offset rack bit should be facing forward?
