Driftworks v2 front lower controll arms
Thread in 'Technical Questions' started by Mathew Mower, Oct 10, 2020.
  1. Mathew Mower
    Mathew Mower New Member
    Cork
    Hi all... today I’m tackling the front lower controll arms.. before I tighten up I want to check I’m heading in the right direction and they are the right way around.. 09ED6B3F-2D47-4CC6-9CE1-8DEED6D786D0. Also should the tension rod go through both holes?? E48A9944-F99D-4292-8590-3907D0E567F5. I’m thinking the sway bar should fit into the furthest hole..
    Any info would be great
  2. oloya Chrispekarton
    oloya Chrispekarton New Member
    Gulu uganda
    Follow this procedure,
    Make sure you rearrange you tools plus all the equipment orderly before you begin to fit ,this will help you a lot in making proper set up
    • Creative Creative x 1
  3. tomsheen
    tomsheen Active Member
    Ireland
    That’s all wrong anyways don’t drive the car please. It’s hard to explain coz you’ve too much wrong. I’ll try find a good picture for ya.
  4. tomsheen
    Ireland
    Note the spacers. This is how it fits together.
    EF169DC6-DA79-4A1B-AC2B-5035BBE38342.
  5. Mathew Mower
    Cork
    Cheers.
    #5 Mathew Mower, Oct 11, 2020
  6. Mathew Mower
    Cork
    Cheers.. it took me awhile but I figured it out... the spacer went into the lower part on the arm and the bolts through both holes, with the silver gear washer goes on top like above.. It took me about 9 hrs to do both sides because I had trouble again removing the old split pins as they broke but nothing a grinder couldn’t sort out! 9927C7E6-922A-4161-8134-25D8DDD59BA3.
    #6 Mathew Mower, Oct 11, 2020
