DW Front Lower Control Arms have play
Thread in 'Technical Questions' started by turbotank, May 30, 2014.
  1. turbotank
    turbotank Member
    so my drift works front lower control arms have play in them…. on both the subframe ROSEJOINT side and also the hub SPHEARICAL BEARING side..
    can anyone tell me what size rose joint rod end what size spherical bearing i need to replace what is in my arms currently.
    i know they can be had on mcgill motorsports just need to know the right size… anyone has done this before??
    i need to replace these ASAP for an MOT
  2. turbotank
    turbotank Member
    or can the spherical bearings even be removed?replaced? … let me know guys thanks!!
    if anyone has there arms off the car can you let me know the size of the inside of the spherical bearing
  3. SteveC200
    SteveC200 Used to drift, now I don't.
    Essex
    Try giving DW a call, they are quite likely to know the answers.
  4. Speedmast
    Speedmast New Member
    Scotland
    Bought mine from mcgill motorsports.
  5. turbotank
    turbotank Member
    did you buy the rose joints that connect to the subframe? or did you buy the spheric bearing that has the kingpin going through it that connects to the Hub ??? or both? :) from mcgill .. let me know thanks
  6. Starkey
    Starkey Administrator
    Staff Member
    Birmingham
    We have the replacements in stock, drop us an email sales@driftworks.com
