dw hydro lines on s14a
Thread in 'Driftworks Products & Enquiries' started by littleT_23, Apr 15, 2014.
  1. littleT_23
    littleT_23 Member
    I ve just fitted your hydeo lines to my s14a. All fits ok. I ve fitted them the same way in your picture keeping abs pump and standard 14a t piece and the hydro doesnt lock the rear wheels. Do I need to change the rear t piece?
  2. Jizzle
    Jizzle Member
    what handle are you using? and whats the condition of your rear brakes? all OEM s14 stuff?
  3. littleT_23
    littleT_23 Member
    Grooved discs. Not sure what pads but loads left on them. The hydro is a 0.625 master cylinder. Standard calipers.
  4. Jizzle
    Jizzle Member
    Probably needs bleeding some more mate, s14 rear brakes are the best but should still lock up with a good tug! lol
  5. kam
    kam I've touched Chris Parry
    All boils down to 1) how good your rear brakes are (caliper condition, pads/discs) 2) how you're using it.
    Does it feel ok? As in firm when you pull it?
    Apparently the rear T has a restrictor in it, never looked myself though.
  6. littleT_23
    littleT_23 Member
    Hydro sorted. Handbrake cables to tight. Slack them right off. Warmed the rear brakes. Hydro now locks.
