For Sale E30 330i M54B30 swap LHD
Thread in 'Drift cars for sale' started by keysdrift, Aug 14, 2019.
  1. keysdrift
    keysdrift New Member
    Aberystwyth
    CAR:
    1987 318i e30 (LHD);
    around 110K Miles on chassis;
    registered and insured in POLAND, all paperwork necessary to register it in UK available.
    ENGINE and GEARBOX
    M54B30 swap;
    sintered clutch;
    light flywheel;
    braided clutch line;
    e46 5 speed ZF box;
    Condor Speed Shop engine and gearbox mounts;
    EWS removed
    SUSPENSION and BRAKES
    Rear:
    KYB shocks and stiff spring with adjustable height;
    unmounted toe and camber plates;
    STRONGFLEX yellow trailing arm bushes;
    e36 323ti compact rear end;
    new Mtec drilled and vented rear discs + new pads;
    Front :
    Basically new vented e30 325i setup 4x100 + adapters 5x120;
    Unbranded coilovers;
    braided brake lines all around;
    I have stuff for front 5 lug conversion available - e36 knuckles, 328i calipers (freshly rebuild and powder coated)
    GEARSHIFT: (full CONDOR SPEED SHOP rebuild kit)
    Z3 1.9 lever;
    new bit*ch clip;
    e36 328i shifting arm with new condor oval bushings;
    e36 328i selector rod;
    solid rear shift carrier bushing;
    DRIVETRAIN:
    4.10 welded diff with STRONFLEX yelow diff mount bush;
    2x set of standard e36 compact driveshaft
    1x set of thick e36 323ti compact driveshaft
    BODY:
    Floor and sills are solid - you can jack car up on seals
    have some rust spots
    OTHERS:
    - Full interior except seats - car have only one seat (e36 driver)[can add bucket seat frame];
    - CAR RUNS AND DRIVES!!!
    - Front and rear strut brace
    - Car comes on steel wheels with extra set of OEM e31 styling 8
    16x7.5+15 (4th photo)
    - car needs some work and finishing touches.
    Car is located in Aberystwyth, Wales.
    PRICE: £2,500 ONO
    Need it gone, try me!
    IMG_5629.JPG IMG_5631.JPG IMG_5658.JPG IMG_4651.JPG IMG_4630.JPG IMG_4633.JPG IMG_4647.JPG IMG_4643.JPG IMG_4649.JPG 49596114_10212915859667017_7348658252835454976_o. 49896135_10212915859787020_2335546612190806016_o. IMG_5629.JPG IMG_5631.JPG IMG_5658.JPG IMG_4651.JPG IMG_4630.JPG IMG_4633.JPG IMG_4647.JPG IMG_4643.JPG IMG_4649.JPG 49596114_10212915859667017_7348658252835454976_o. 49896135_10212915859787020_2335546612190806016_o.
