for sale my e30 had enough of it now and starting to get bored ! location herne bay in kent it has a 6 point omp cage lsd yellow tinted lights mocal oil cooler on the left and air duct and fog on right flared rear arches re-painted in calypso red 2.5 engine with fresh water pump cambelt and thermostat all done by myself when I changed the engine (wich is on 80k with clocks to prove that came from a c reg e30 325 4 door front and rear eibach anti roll bars jom coilovers 10j rear, 9j front banded steels 195/50/15 rears loads of tread 195/45/15 fronts loads of tread left. stripped out with almost crack free dash just a small one that you hardly see ! 3 point harnesses (budget ones) new wiper blades sports seats (drivers one is shredded but with a cover or re-cover is fine) spare ecu,coils,battery relocation kit to rear,ht leads,and much more a 323 engine from e36 with gearbox ecu diff prop bad points windscreen has a chip couple of small imperfections as it was a budget paint but still looks very good had drums on rear needs a lick of paint inside ok now the bad bits are out the way a price !! all mot,d and complete I want £2100 contact 07858235782 pics any more needed I will post them up
early to late spec engine so had no other way and its only 1 pipe runs sweet though !!! also forgot to add this is the early hi compression lump
